Important Notice: Beware of Fake Garmin Ads!
Garmin Malaysia has received reports of fraudulent websites and advertisements circulating on social media, claiming to sell Garmin products at discounted prices. Do not click on suspicious links or provide personal information on unverified sites.
Always shop through the official Garmin website. Your safety is our top priority.
Transmitting NMEA 2000 Data Wirelessly to a quatix
The quatix®* has the ability to connect to a NMEA 2000 network wirelessly and display data preset on the network.
Required Equipment
A GNT™ 10 is required to be installed on the NMEA 2000 network in order to transmit data to the watch.
Available Data Fields
  • AWA (Apparent Wind Angle) - The wind angle measured with respect to the bow of the vessel.
  • A WIND CHL (Apparent Wind Chill) - The temperature of the wind chill relative to the boat.
  • AWS (Apparent Wind Speed)  - The measured speed of the wind.
  • CARDWIND (Cardinal Wind Direction) The true wind direction described in cardinal directions.
  • DEPTH - The depth of the water.
  • DRIFT - The speed of the current.
  • GWS (Ground Wind Direction) - The direction of the wind relative to the land, reference from the north.
  • G WIND CHL (Ground Wind Chill) - The temperature of the wind chill relative to the land.
  • GWS (Ground Wind Speed) - The speed of the wind relative to the ground. If there are no current and no leeway, the ground wind speed is equivalent to the true wind speed.
  • OPP TACK (Opposite tack heading) - The opposite tack direction of the vessel based on the current tack direction.
  • SET - The direction of the current referenced from the north.
  • STW (Speed Through Water) - The speed of the boat relative to the water.
  • TWD (True Wind Direction ) - The true direction of the wind relative to North.
  • TWS (True Wind Speed) - The true speed of the wind relative to the vessel.
  • VMG TO WND (Velocity Made Good to Wind) - The speed at which you are making progress into the wind.
  • WATER TEMP (Water Temperature) - The temperature of the water.
*This article does not apply to the Quatix 3 or Quatix 5
