Save Part of a Track Log as a Route
Your device has the ability to convert previously traveled trip data into a route for future use.
To Save a Segment of Your Trip/Track Log as a Route:
Touch Apps or
Touch Tracks
Touch
Select the desired track
Touch the wrench icon
Touch Save As Route or Save as Trip
Select the preferred routing preference, either Start to Finish or Finish to Start
Input a name for the new route
Touch Done
Once calculated, you can go to Trip Planner and touch Map to see the route the unit created. You may also edit the route to change the points on it or touch Go! to start the route you created from the trip log.
To Convert a Saved Track to a Route:
Touch Apps, or
Touch Tracks
Touch Info
Skip this step on some devices
Touch Save as Trip or Convert to Route
Touch Done
