(2022) Service Bulletin 22071 Rev A: GTN Xi Main Software v20.24, GPS/WAAS v8.2, COM v2.02, NAV v2.04, and GMA35/c Audio ARC DB v4.22C
PRODUCTS AFFECTED:
The following units are affected:
ModelAppliance P/N
GTN 625Xi011-04629-00
GTN 635Xi011-04630-00
GTN 650Xi011-04631-( )
GTN 725Xi011-04632-00
GTN 750Xi011-04634-( )
GMA™ 35011-02299-2( )
GMA 35c011-02299-4( )
COMPLIANCE:
Recommended: Compliance with this Service Bulletin is recommended at the next scheduled maintenance interval for installations with Main Software Version 20.10 through 20.23.
For all other installations this service bulletin is optional.
PURPOSE:
GTN Xi Series Main Software Version 20.24 fixes an issue with the use of the GPS Antenna Height Above Ground configuration setting. This setting is used to determine the GPS altitude of the airplane by compensating for the mounting height of the GPS antenna on the aircraft.
WARRANTY INFORMATION:
For GTN Xi installations with Main Software Versions 20.10 through 20.23, this modification is warranty reimbursable with a deadline of August 31, 2023.
For all other installations this service bulletin is not warranty reimbursable.
Related
