Garmin Legacy Product Is Not Detected by Garmin Applications
USB communication issues can prevent Garmin applications from communicating with Garmin devices. Check the following to determine if your device is properly connected to the computer:
  • Try a different USB port on the computer.
  • Turn the device off and then back on again.
  • Plug the USB cable directly into the device and the other end directly into a USB port on the computer. Do not use a hub or docking station.
  • Ensure the USB cable is a sync cable.  Some USB cables are charging cables only, and do not transmit data. The cable that came with the device is a sync cable and will show GARMIN on the USB plug.
  • Home computers on home networks are preferred. Business computers and networks may not allow the use of Garmin applications.
  • Try another USB cable or another computer.
Older Garmin products are not compatible with all Garmin programs. Open the chart below to determine which Garmin programs your legacy Garmin product is compatible with.
Application Compatibility Chart for All Outdoor Legacy Products
NOTE: MapSource® software can be used for legacy outdoor handhelds that are not compatible with BaseCamp™ software. If you encounter a "Previous MapSource Not Found" error while installing the MapSource program this can be resolved by installing the BaseCamp program first, then running the MapSource program install again. Installing BaseCamp software will load the necessary background files required for the MapSource program to install and run on the computer.
BaseCampGarmin ExpressMapInstallMapSourceWebUpdater
eTrex® HandheldXXXYesYes
eTrex® H HandheldXXXYesYes
eTrex Legend® HandheldXXXYesYes
eTrex Legend® C HandheldYesXYesYesYes
eTrex Legend® H HandheldYesXYesYesYes
eTrex Legend® Cx HandheldYesXYesYesYes
eTrex Legend® HCx HandheldYesXYesYesYes
eTrex Summit®  HandheldXXXYesYes
eTrex Summit® HC Handheld YesXYesYesYes
eTrex Venture® HandheldXXXYesYes
eTrex Venture® HC HandheldYesXYesYesYes
eTrex Venture® Cx HandheldYesXYesYesYes
eTrex Vista® HandheldXXXYesYes
eTrex Vista® C HandheldYesXYesYesYes
eTrex Vista® H HandheldYesXYesYesYes
eTrex Vista® Cx HandheldYesXYesYesYes
eTrex Vista® HCx HandheldYesXYesYesYes
Foretrex® 101 GPS NavigatorXXXYesYes
Foretrex® 201 GPS NavigatorXXXYesYes
Foretrex® 301 GPS NavigatorYesXXYesYes
Foretrex® 401 GPS NavigatorYesXXYesYes
Geko™ 101 HandheldXXXYesYes
Geko™ 201 HandheldXXXYesYes
Geko™  301 HandheldXXXYesYes
GPSMAP® 60 HandheldYesXYesYesYes
GPSMAP® 60C HandheldYesXYesYesYes
GPSMAP® 60CS HandheldYesXYesYesYes
GPSMAP® 60Cx HandheldYesXYesYesYes
GPSMAP® 60CSx HandheldYesXYesYesYes
GPSMAP® 76 HandheldYesXYesYesYes
GPSMAP® 76C HandheldYesXYesYesYes
GPSMAP® 76S HandheldYesXYesYesYes
GPSMAP® 76CS HandheldYesXYesYesYes
GPSMAP® 76Cx HandheldYesXYesYesYes
GPSMAP® 76CSx HandheldYesXYesYesYes
Rino® 110 HandheldXXXYesYes
Rino® 120 HandheldXXXYesYes
Rino® 130 HandheldXXXYesYes
Rino® 520 HandheldYesXYesYesYes
Rino® 520 HCx HandheldYesXYesYesYes
Rino® 530 HandheldYesXYesYesYes
Rino® 530 HCx HandheldYesXYesYesYes
If These Steps Did Not Resolve the Issue
See Related at the bottom of this page for further troubleshooting. If none of that helps, or does not apply to your issue, visit the Garmin Express™ software section of Support Center.
Related
