Where Is the Serial Number for My Vector Pedals?
The serial number for a Vector product is only located on the box of the device. You can obtain what is called the Unit ID which can be converted into the serial number by Garmin Product Support.
Below are general steps. For specific steps you will need to refer to your Owner's Manual
Access the Menu of your device
Locate the screen where you add sensors
Choose Vector
Select Sensor Details (skip this step on some devices)
Select About
The unit ID should be displayed here, although it may be labeled as serial number on some devices.
