Steps to Create a Manual Activity in the Garmin Connect App
Garmin Connect App will allow you to manually enter an activity using basic information. This feature can be used when you are unable to record an activity because of an issue with your fitness device or when you do not have access to a fitness device.
To add a manual activity in Garmin Connect App:
  1. Open Garmin Connect App
  2. Access the Menu
    • Android: Select ( upper left)
    • iOS: Select More (lower right)
  3. Select Activities
  4. Select Create Manual Activity
  5. Enter all applicable fields
  6. Select Save
Your manual activity is now entered.
