Automotive Devices That Display POI Icons on the Map
Your device will display icons for nearby points of interest (such as restaurants or gas stations) when you are navigating a route and have the Up Ahead Places map layer enabled.
To enable the Up Ahead Places map layer:
- Touch Settings
- Touch Map & Vehicle
- Scroll down and touch Map Layers
- Touch to add a checkmark on Places along the road if not already selected
- Touch Save
The device will now display icons for upcoming restaurants, banks, and gas stations on the map.
For POI icons to be visible, your device must be in an active route (i.e. the device is currently navigating to a specific point) and the map must be zoomed in to at least 2 miles. The farther zoomed out the map is, the fewer POI icons will be displayed. At 3 miles, only the icons for saved locations will be shown. No icons will be visible beyond 3 miles.
Although POI icons will be visible in all three map views, the zoom level will only be shown in the North Up and Track Up views.
To change the map view on your device:
- Touch Settings
- Touch Driving Map View
- Select the desired map view
- Touch Save
The map view will now be changed.
