Basics of Garmin Transducer Installation
There are a few different ways to mount a Garmin transducer. Below are some examples, descriptions, and tips for each mounting style:
NOTE: The information presented is general and not a complete transducer placement or installation guide. Read the installation instructions for the specific transducer during installation. If there is any question about what mounting style is best for any particular vessel, contact the boat manufacturer.
Interference and routing of cable considerations
Electromagnetic interference (EMI) may distort sonar information and images. Placing a transducer or routing the transducer cable near a source of EMI may degrade sonar information. Sources include but are not limited to:
Bilge pumps
Magnets
AC/DC power cables
Batteries
Trolling motors
Electrically charged devices and equipment
Transom Mount and Step Mount
Transom mounted transducers are attached to the back of the transom of a vessel. Trailered vessels typically use this mounting style. A transom-mounted installation usually gives good readings up to 25-30 mph depending on installation. Transom-mounted transducers are not compatible with jet propulsion vessels. The jet exhaust creates a vast amount of water turbulence that may result in degrading the sonar signal so that it cannot effectively move through the water column to get a good sonar return. If the boat is a jet propulsion vessel, utilize the techniques found in the "In Hull" or "Through Hull" installation procedures.
Choose a location where the water flow is the smoothest, and minimum turbulence and bubbles will exist, especially at high speed
The transducer requires continuous contact in water, and the sounder beam is unobstructed by the keel or propeller shaft
Make sure that there is adequate headroom and there is a minimum deadrise angle
Look for features on the hull like lifting strakes or keels. These structures will cause cavitation and will negatively affect performance. A disadvantage of a transom mount is that air bubbles will affect the sonar performance
The location should be as close to the center of the boat and on the side prop wash. On most engines, this will be on the starboard (right) side
On boats with outboard or inboard/outboard motors, the location should be at least 15 inches (38 cm) away from the propeller
The location should not be in the path of the propeller on single-drive boats. The transducer can cause cavitation that degrades the boat's performance and could damage the propeller
The location should not be downstream of any strakes, struts, fittings, water intake or discharge ports, or anything that creates air bubbles or causes the water to become turbulent
The location should be between the drives on twin-drive boats, if possible, and only if the propellers swing in a rotation that causes the downswing of the propellers to cause the cavitation to hit the back of the transducer instead of the face
Avoid locations where physical jarring of the transducer could occur. Consider the position of the transducer when launching, hauling, or storing
The transducer should be oriented so that it is parallel with the waterline
Transom-mounted transducers are not compatible with jet propulsion or drive vessels. The jet exhaust creates a vast amount of water turbulence that may result in degrading the sonar signal so that it cannot effectively move through the water column to get a good sonar return. If the boat is jet propulsion or drive vessel, utilize the techniques found in the "In Hull" or "Through Hull" installation procedures
NOTE: Step Mounting a transducer follows the same steps as the Transom transducers do. The difference is that the transducer will mount on the step instead of the transom.
When installing a transom-mounted transducer, it is crucial to carefully follow the installation instructions provided within each transducer kit. The following are basic guidelines to consider when mounting this type of transducer:
Below is an image of a sample installation and doesn’t apply to every boat.
Speed Sensor
The speed sensor’s installation is not as critical as the depth transducer installation. The guidelines will be like those above, but there are other considerations:
Take care to avoid mounting it too close to a transom-mounted depth transducer, as it can potentially cause cavitation that will degrade sonar performance
If there is adequate room, it’s advisable to mount the speed sensor on the port (left) side of the engine propeller
Closely following the packaged manuals and the tips outlined above will have the best opportunity to have an easy installation and optimal performance from the transducer.
In-Hull Mounting
An in-hull transducer installation is bonded to the inside of the hull with epoxy and will typically consist of a container filled with propylene glycol. When installing an in-hull mounted transducer, it is essential to carefully follow the installation instructions provided within each transducer kit. The following are basic guidelines to consider when mounting this type of transducer:
In-Hull Pros and Cons
No need to drill through the vessel; no drag
Trailering the boat without causing damage to the transducer
Can be installed and serviced with the ship in the water
Excellent high-speed performance if water flow below the sensor is free-flowing (no turbulence)
Works with any engine type: inboard, outboard, and I/O when installed over solid fiberglass
Performs well on both power and sailboats
Not recommended for metal, wood or cored fiberglass hulls
Loss of signal by transmitting through-hull
Placement of the In-hull transducer
Close to the centerline
The signal will pass through up to 0.75” thickness
The GT8HW-IH transducer is rated at 250W so the hull thickness cannot be greater than .50" thickness
Avoid mounting too close to the keel; cone signal shape is approximately 22 degrees. If too close to the keel, it can pick up an echo
Should be in the aft of the boat
Do not mount the transducer behind strakes, struts, fittings, water intake or discharge ports, or anything that creates air bubbles or causes the water to become turbulent
The vessels hull that is directly underneath the transducer must be in constant contact with the water
The transducer must be in clean, flowing water (non-turbulent) water for optimal performance
Test the location - use a thin plastic bag filled with water, place the transducer inside the bag, and close with a zip tie. Use water to wet the desired hull location. Plugin transducer and check the chartplotter’s sonar page for good returns
Periodically check the tank and fill when needed with propylene glycol. Flashing depth or no depth information indicates that there is not enough fluid or no fluid in the reservoir
Thru-Hull Mounting
Thru-hull transducers are just that; a hole through the hull of the boat with the transducer installed through the hole. Thru-hull transducers come in two versions, tilted element or with a fairing block. Garmin also has SideVu transducers. If the hull has a deadrise of more than 5 degrees, a pair of thru-hulls will be required.
There are specific placement locations based on the type of hull and type of engine on the vessel be sure to read through the manufacturers mounting considerations before drilling a hole.
Below are some general guidelines for placement. Because of the complexity of thru-hull installations, Garmin does recommend a professional installer for this type of transducer installation.
Outboard and Sterndrive Vessels: the transducer should be mounted in front of and close to the engine or engines
Inboard Vessels: the transducer should be mounted in front of and far away from the engine propeller and shaft
Step-hull Vessels: the transducer should be mounted in front of the first step
Full-Keel Vessels: the transducer should be mounted at a slight angle that aims at the bow, not parallel to the centerline
Fin-Keel Vessels: the transducer should be mounted 10 – 30 inches (25 cm – 75cm) in front of the keel and a maximum of 4 inches (10 cm) to the side of the centerline
Displacement Hulls: the transducer should be mounted approximately 1/3 aft of the waterline length of the vessel from the bow, and 6 – 12 inches (150 – 300 mm) to the side of the centerline
The transducer mounted parallel to the bow-stern axis of the vessel
The transducer location should not cause jarring when launching, hauling, or storing
Single-Drive vessels: the transducer must not be mounted in the path of the propeller. The transducer can cause cavitation that can degrade the performance of the boat and damage the propeller
Twin-Drive vessels: the transducer should be mounted between the drives, if possible
The preferred mounting location for the transducer is on the starboard side of the hull, where the propeller blades are moving downward
Thru-hull no fairing block required Thru-hull with fairing block.
SideVü™ Thru-Hull transducers are installed similarly to a single thru-hull with the exception that a second thru-hull is on the opposite side of the vessel. There is a cable to connects the pair of transducers, and then a single cable is plugged into the chartplotter. A pair of transducers is required if the deadrise is greater or there is no flat spot on the bottom of the boat.
Trolling Motor Mounting
Mounting a transducer on the trolling motor is a second mounting option available for some transom mount transducers. Typically, the transducer attaches to the bottom of the trolling motor body.
Pay special attention and care when routing the cable up the shaft of the trolling motor. It is crucial that when stowing the trolling motor, the transducer cable does not get pinched or worn
Trolling motor power cable should be routed away from the trolling motor transducer
Trolling motor should be powered by a battery separate from the chartplotter
Trolling motors throw off a lot of interference. Use ferrite beads on the transducer cable to help minimize this interference. Install these near the connector head
Trolling motor mounting is also available for select Panoptix™ transducer as well. Mounting a forward-looking Panoptix transducer to the shaft of the trolling motor will provide the user with the ability to rotate the transducer to look at a specific area without having to turn the entire boat.
Traditional Transducer LiveScope™ Transducer Shaft Mount LiveScope™ Transducer Barrel Mount
Trolling Motor Considerations:
GT transducers and some third party transducers may provide 3D structural down and side view imagery. These 3D structural views require the transducer to remain as straight as possible. As the transducer spins, the imagery drawn is based off of which way the transducers side and bottom surface is facing. These views work best when in a heading hold. Traditional 2D is not effected by the rotating transducer.
NOTE: Garmin's Force Trolling Motor uses a brushless motor and should not produce any electromagnetic interference. The built-in transducer on a Force Trolling Motor uses a 12-pin connector and supports Ultra Hi-Definition ClearVü™ sonar & SideVü™ sonar. The transducer will work with some units that only support regular ClearVu and SideVu imagery.
Ice Fishing Transducers
When placing the transducer through the ice, the top of the transducer needs to be under the bottom of the ice layer. Adjusting the beam width might be needed depending on the depth of the ice. In addition, silty or absorbent lakes, rivers, creeks, or sea beds may prevent bottom returns, as the echo is absorbed and not returned. The same is true in shallow water with hard surfaces. These surfaces may ping back so loudly and hard that they may bounce off the surface of the ice. If adjusting frequency, adjusting beam width, and or restoring sonar defaults do not resolve the issue, moving to another location on the ice may be necessary.
NOTE: With the exception of LiveSope™ Transducers being used for ice fishing, GT Ice fishing transducers do not have built-in temperature sensors.
If the depth or temperature of the Garmin transducer is incorrect, refer to the devices owner's manual.
