Change display colors on Garmin automotive devices
The background screen colors on Garmin automotive devices cannot be adjusted or changed. However, you can switch between Daytime or Nighttime color mode options.
To adjust this option, follow the steps below:
  1. Touch Tools
  2. Touch Settings
  3. Touch Display
  4. Touch Color Mode
  5. Touch the desired color mode
The following color modes are available:
  • Day - Provides a white background to improve visibility during daylight hours
  • Night - Darkens the background to prevent the screen from being too bright or distracting when driving in the dark
  • Auto - Allows the device to automatically change the color mode based on sunrise and sunset times. This is the default color mode setting
In addition to the color mode, some automotive devices allow you to change the colors used on the map screen by using map themes. For more information on which devices allow this and how to change the map theme being used, see Related Content.
Related
