Automotive device prompting to simulate route
If you need to, you can use your device indoors or in a location where you cannot get an adequate GPS signal. When this happens, the device uses your last known location and simulates navigating a route. The device is not locked onto satellite signals but acts as though it is navigating a route.
Your device must have a clear view of the sky to acquire the satellite signals. If your device's GPS Simulator is enabled then you will need to disable it from the System settings.
To simulate a route, see Related Content.
Related
