(2023) Service Bulletin 23113 Rev A: Approval of GTS 800 Main Software Version 4.13 and FPGA Version 2.10
PRODUCTS AFFECTED:
GTS 800 systems installed using GTS 8XX Part 23 AML STC SA02121SE are affected.
CERTIFICATION AUTHORIZATION:
STC SA02121SE MDL Revision 5
COMPLIANCE:
Optional: This Service Bulletin may be incorporated at the owner’s discretion and is not warranty reimbursable.
DOCUMENTATION CONSIDERATIONS:
As a result of changes related to this update, the applicable documents listed in Table 1 are required to be issued to the aircraft operator/owner before the aircraft is returned to service.
Table 1
| Document Title | Part Number | Revision (or later) |
| GTS 8XX Part 23 AML STC Maintenance Manual with Instructions for Continued Airworthiness | 190-01279-01 | 2 |
| AFMS, GTS 8XX Part 23 AML STC | 190-01279-02 | 2 |
PURPOSE:
This STC Service Bulletin provides notification of an update to the AML STC SA02121SE Master Drawing List revision 5 to update GTS 800 main software to version 4.13 and FPGA software to version 2.10. This software update adds support for the GI 275.
WARRANTY INFORMATION:
This modification is not warranty reimbursable.
