Magnification Gestures on an Android Based Automotive Device
Some devices have the option to enable Magnification Gestures. This is an Android feature not supported by Garmin.
This feature allows you to zoom in and out by triple-tapping the device's screen. This can become an issue when typing on the device or selecting an option more than once quickly, as this will cause the feature to zoom in.
To Disable Magnification Gestures on Your Device:
Tread® XL - Baja Chase Edition, Tread® XL - Baja Race Edition GPS navigators:
1. Select Apps
Baja apps
2. Select Tools
Baja tools
3. Select Settings
Baja settings
4. Select System
Baja system
5. Select Accessibility
Baja accessibility
6. Select Magnification, Disable/Enable as desired
Baja Magnification
All Other Devices:
1. Select Settings
Settings otr 800
2. Select System
Select system otr 800
  • On some devices, skip this step as System is a header and not selectable
Skip Step Dezl 785
3. Select Accessibility
Select accessibility otr 800
4. Select Magnification gestures or Magnification
Select magnification gestures otr 800
5. Disable/enable feature as desired
