Delta Sport XC Levels of Stimulation
The Delta Sport™ XC remote training system provides several training modes, which assign different combinations of momentary and continuous stimulation, tone, and vibration.
The three vertical letters on the LCD display correspond to the training key functions, from top to bottom.
delta handheld screen with numbers
Training Keys that activate a stimulation are designated as high or low. The chart below explains each training mode.
Chart with mode settings
It is possible to get up to 36 levels of stimulation. Depending on settings you can get a high and a low on the same number. For example, if you set to mode MCC and a level 3, the device will deliver a momentary correction on the top button, a high continuous level 3 on the middle button, and a low continuous level 3 on the bottom button.
