Getting Started with the Instinct Solar and Instinct Solar Camo
Below is a list of articles that will help you get started with, and get the most out of, your new Garmin Instinct® Solar watch.
How Do I Get Started?
You can choose to either follow the below instructions or watch a video for the process to set up your Garmin Instinct Solar watch.
Before getting started, we recommend that you fully charge your Instinct watch. See Charging the Device to learn how.
  1. Power on the Instinct Solar by holding the CTRL button.
    Learn About the Buttons
    Instinct Solar Overview
  2.  Choose your language by scrolling through the list, use the GPS button to select your language.
  3. Pair your watch with your smartphone following the on-screen instructions (optional).
    NOTE: Pairing the watch with Garmin Connect™ will also register the watch.
    Learn More About Bluetooth Pairing
  4. The next steps allow you to set your user preferences, simply follow the on-screen prompts to complete the setup process.
How to Record Your First Activity
To start using activities, choose your preferred activities.
  1. Press the GPS button.
  2. Locate your activities by using the Up or Down buttons to scroll through the list. Press GPS to select an activity.
  3. Use the Down button until you see Done on the screen. Press GPS to save your selections.
  4. To start using activities, see How to Start an Activity.
TIP: If you want to add activities, see - How to Add an Activity on a Garmin Outdoor Watch.
Other Articles You Might Find Useful
