Delta Dog Collar Status LED Lights
The Delta®, Delta XC, and Delta SE dog training collars will display a variety of different light sequences depending on what state/mode the system is in.
NOTE: This list does not cover the Delta Smart™ or Delta Inbounds™ systems.
Select an option below for more information.
While On the Charger (All Models)
Solid Red
Charging
Solid Green
Fully Charged
Training Only Mode (All Models)
Green, Double Flash
Collar is active and the battery has a good charge.
Yellow, Double Flash
Collar is active and the battery has less than 50% charge remaining. Battery should be charged soon.
Red or Amber , Double Flash
Collar is active and has a very low charge. Battery should be charged.
Red, Continuous Flash
Collar is no longer active, battery has depleted and needs to be charged.
BarkLimiter™ Only Mode (Delta Sport™ and Delta Upland™ models, including XC)
No Status Lights
Collar is stationary, collar is not sensing movement or barks but is active.
Red or Amber, Quick Flash
General movement is being detected. No correction has been applied. This flash happens every 3 seconds during movement.
Green, Long Flash
Bark Correction is being applied. This flash happens every 4 seconds during movement.
Training and BarkLimiter Mode (Delta Sport XC and Delta Upland XC Models Only)
Green, Double Flash
Collar is active and battery has less than 50% charge remaining. Battery should be charged soon.
Red or Amber, Double Flash
Green, Long Flash
