You are viewing an article that is not available in your currently selected language. You can choose another one below.
ecoRoute HD Cable not Pairing with a dēzl™ 560
There may be times when the ecoRoute HD cable will not pair with your device. Correcting this issue can be accomplished by following the steps below:
Update the device software
The software on your device can be updated using Garmin Express.
Set the transportation mode to automobile
The dēzl™ can only utilize the ecoRoute HD while in automobile mode. To change the transportation mode:
- Touch the vehicle icon at the top of the main menu
- Touch Automobile
- Touch Save
Enable the device's Bluetooth
For instructions enabling the Bluetooth, go to Pairing a Bluetooth phone with an Automotive device.
Pair the ecoRoute HD accessory
For instructions pairing the ecoRoute HD accessory, go to Pairing an ecoRoute HD accessory cable to a Garmin device.
Reset the ecoRoute HD accessory and device
If the ecoRoute HD accessory and device still aren't pairing, reset both using the instructions below:
- How to use the ecoRoute HD accessory reset button
- Hold the power button on the automotive device for 8-10 seconds
