(2022) Service Advisory 22060 Rev A: Loading Databases
PRODUCTS AFFECTED:
Garmin G1000 NXi with Software Versions GDU™ 20.59 and earlier are affected.
ISSUE:
The G1000 NXi will not see databases (or will encounter syncing issues) when loading databases directly to the Flight Stream 510 using a computer.
ACTION:
Do not load databases directly to the Flight Stream 510 using a computer. Use the Database Concierge WIFI to wirelessly transfer databases to the Flight Stream 510 or load the databases to a separate SD card.
RESOLUTION:
This is fixed in G1000 NXi with Software Versions GDU 20.60 and later.
