Microsoft .NET Framework Error While Installing or Using a Garmin Application
Microsoft .NET Framework is the foundation for Garmin applications.
If Microsoft .NET Framework displays an error during the installation or operation of an application, the problem will need to be resolved before the application can be used.
Versions of Microsoft .NET Framework Required by Garmin Applications:
Microsoft .NET Framework 4.6.1:
  • Garmin VIRB Edit
Microsoft .NET Framework 4.6:
  • Garmin BaseCamp™ software
  • Garmin HomePort
Microsoft .NET Framework 4.7.2:
  • Garmin Express™ software
Microsoft .NET Framework 3.7:
  • inReach Sync
Microsoft .NET Framework 3.5:
  • All other current applications
Resolution - Check for Windows Updates:
NOTE: If you do not feel comfortable with the steps below, use another updated, compatible computer.
To resolve an issue with Microsoft .NET Framework, first ensure that all Windows updates are installed. This will install the latest updates to .NET Framework too.
Windows 10 or Newer
1. Click the Windows Start icon.
Red box around Windows 10 Start Icon
2. Click the gear Settings gear.
Location of Settings Gear in Start Menu
3. Click Refresh Arrows Update & Security.
  • Skip this step on some computers
Settings Window
4. If necessary, click Refresh Arrows Windows Update.
Red box around Windows Update
5. Click Check for updates.
Red box around Check for updates under Windows Update screen
If the issue persists, download and run Microsoft's .NET Framework Repair Tool.  If you encounter issues with Microsoft's .NET Framework Repair Tool, contact Microsoft.
After repairing the .NET Framework with this tool, Garmin applications should install and launch.
