Android: How to Send a Crash Report
If you are experiencing a crashing problem, sending a crash log will help us with our investigation.
NOTE: You may be asked to do this in order for us to better analyze the issue you are experiencing.
To get a crash log for the Navionics® Boating app from your Android device, do the following:
- Be sure you have Developer Options enabled
- In Developer options, tap Bug report
- Select the type of bug report you want and tap Report
After a moment you get a notification the bug report is ready - To share the bug report, tap the notification
To enable developer options, tap the Build Number option 7 times. You can find this option in the following location, depending on your Android version:
Android 9 (API level 28) and higher - Settings > About Phone > Software information> Build Number
