Not Enough Memory Error for My Edge in Garmin Express
Seeing a "Not Enough Memory" error in the Garmin Express™ program when installing initial map updates on certain Edge® cycling computers, is likely due to the inclusion of the Navigation Free ClimbPro maps which require additional space.
To resolve this error, use Managing Maps in Garmin Express to deselect one of the regional maps or keep an entire region and a subset of another region enabled, provided there is sufficient storage on the device. This can be done on the following Edge cycling computers:
Edge® 540 | Edge® 540 Solar
Edge® 840 | Edge® 840 Solar
Edge® 1040 | Edge® 1040 Solar
Edge® 1050
Edge® MTB
To Remove a Regional Map
Connect your device to your computer with the USB charging cable.
Launch Garmin Express.
Select your device.
Select Manage Maps.
Un-check the map you want to remove.
Select Apply Changes.
Once the regional TopoActive map is removed, you will now have the enough memory to enable a subset of another region on the Edge.
To Enable a Map Region
Remove then reconnect the Edge to your computer with the USB charging cable.
Select your device.
Select Manage Maps.
Select Change Region below the map region you wish to add.
North America has the following options:
TopoActive Canada/Alaska
TopoActive Middle America
TopoActive United States
Europe has the following options:
TopoActive Central Europe
TopoActive East Europe
TopoActive West Europe
Select a region.
Select Confirm.
Select Continue.
Effective May 7. 2025, Garmin Cycle Maps for Edge® cycling computers and Garmin® watches are being discontinued. The same mapping content will now be included in our TopoActive maps and can be purchased or downloaded on compatible devices. For more information on Garmin TopoActive maps, see Current Version of TopoActive Maps. To update the maps on your Edge, refer to Verifying the Maps Installed on a Garmin Edge Device or your owner's manual.
