Ensure your Phone Meets System Requirements for the dēzl App or Garmin Drive App:
dezl App
Android phones and tablets require Android version 9.0 or later.
Wi-Fi and Cellular capability are required
The dēzl™ app will not be available in the Google Play Store if the app is incompatible with the device being used
Trying to install the app to an incompatible device from the Garmin website will prompt this error: "your device isn't compatible with this version"
iPhones and iPads require iOS 16.4 or later.
- Apple only includes the GPS chipset in the Wi-Fi + Cellular models
Garmin Drive App
Android phones and tablets require Android version 9.0 or later:
- Wi-Fi and Cellular capability are required for full functionality
- The Garmin Drive app will not be available in the Google Play Store if the app is incompatible with the device being used
- Trying to install the app to an incompatible device from the Garmin website will prompt this error message: "Your device isn't compatible with this version"
Apple phones and tablets require iOS 16.4 or later:
Verify your Phone has the Required Permissions Enabled:
See Phone Permissions Required to Use the dēzl™ App and Garmin Drive™ App for more information.
Check for Updates to the Phone’s Operating System:
To Check for Updates on iOS:
(Note: These steps will vary depending on the phone and OS combination)
- Open the phone's Settings menu
- Touch General
- Touch Software Update
To Check for Updates on Android:
1. Touch the Apps menu (some phones skip this step)
2. Touch Settings or the Gear icon
3. Touch About Phone (some phones skip this step)
4. Touch Software Update or System Updates (you may need to scroll down the page)
5. Touch Download and install or Check for system updates (some phones skip this step)
6. Touch Download or Yes if updates are available
7. Touch Install Now
The phone should now check for and apply any necessary system updates.
