File Limitations of the Epix
When sending or creating files for the epix® outdoor handheld, keep in mind the following device limitations:
  • 1,000 waypoints
  • 50 routes, 250 points per route
  • 100 saved tracks
  • 10,000 points per track
  • Unlimited points per fit file (limited only by storage space available on device).
  • Connect IQ™ app supported (watch faces, data fields, widgets and apps); Connect IQ apps may fill available internal memory before file limitations are met.
  • 250 BirdsEye Imagery files
  • mapping segments* vary by model:
    • Approximately 4000 on base model
    • Approximately 3500 on unit preloaded with Topo US 100K maps
Each GPX file can contain a mixture of waypoints, geocaches, routes and tracks. If the GPX file containing a waypoint or geocache is deleted, the waypoint will no longer be available on device.
When utilizing routes, only 50 points can be used for on road navigation.
*See related content for more information.
Related
