USB to 2 Pin Cable Included With GPSMAP® 86i/sci
The USB to 2 pin cable, included with the GPSMAP® 86sci handheld, is an external power cable used to connect the GPSMAP 86 handheld to:
- 12V flying-lead (bare wire) power cable
- Compatible power adapters
- Marine mounts
The half-turn locking connector helps to form a strong connection while helping to eliminate moisture, or debris, from interfering with the power connection.
