Using Voice Control on a Garmin Dash Cam
The voice control feature on Garmin dash cams allows you to operate the camera hands-free by using specific voice commands. This feature enhances safety and convenience, especially while driving.
Garmin Dash Cams with Voice Control:
  • Garmin Dash Cam™ X310 driving recorder
  • Garmin Dash Cam™ X210 driving recorder
  • Garmin Dash Cam™ X110 driving recorder
  • Garmin Dash Cam™ Mini 3 driving recorder
  • Garmin Dash Cam™ Live driving recorder
  • Garmin Dash Cam™ 67W driving recorder
  • Garmin Dash Cam™ 57 driving recorder
  • Garmin Dash Cam™ 47 driving recorder
  • Garmin Dash Cam™ Mini 2 driving recorder
  • Garmin Dash Cam™ Tandem driving recorder
  • Garmin Dash Cam™ 66W driving recorder
  • Garmin Dash Cam™ 56 driving recorder
  • Garmin Dash Cam™ 46 driving recorder
  • Garmin Dash Cam™ 65W driving recorder
  • Garmin Dash Cam™ 55 driving recorder
  • Garmin Dash Cam™ 54 driving recorder
Your Dash Cam "Wake Word"
Voice commands start by saying the wake word for your dash cam. The default wake word is "OK Garmin."  The following devices have the option to change the wake word to "OK, Dash Cam."  This can be useful if you are also using a Garmin GPS navigator device with voice control features.
Changing Your Wake Word
On devices with a built-in display:
  • Select DownMenu > Voice Control > Settings > Wake Word > and select OK Garmin or OK Dash Cam.
Via the Garmin Drive app when your dash cam is paired and connected to your compatible smartphone:
  • From the device settings menu, select Wake Word, and select OK Garmin or OK Dash Cam.
Available Voice Commands
You can use several commands to control the dash cam.  Substitute "OK Dash Cam" for "OK Garmin" if you have changed your wake word.
  • Save a video: Say "OK Garmin, Save Video."
  • Record audio with the video: Say "OK Garmin, Record Audio."
  • Stop recording audio: Say "OK Garmin, Stop Audio."
  • Take a picture: Say "OK Garmin, Take a Picture."1
  • Start Travelapse™: Say "OK Garmin, Start Travelapse."2
  • Stop Travelapse: Say "OK Garmin, Stop Travelapse."2 3
The camera will play a tone after you say OK Garmin to acknowledge that it's listening and second tone when it recognizes your command.
________________________
1Garmin Dash Cam™ Mini 3, Garmin Dash Cam™ X110, Garmin Dash Cam™ X210 and Garmin Dash Cam™ X310 driving recorders do not take pictures.
2Garmin Dash Cam™ Mini 3, Garmin Dash Cam™ Mini 2 and Garmin Dash Cam™ Tandem driving recorders do not offer Travelapse.
3While the Promptly Delete video option is selected in dash cam settings or in the Garmin Drive app, you cannot record Travelapse videos.  See Related Content.
Voice Control Tips
  • Speak in a normal voice directed at the device.
  • Reduce background noise to increase the accuracy of the voice recognition.
  • Before each command, say the wake word. The default wake word is OK, Garmin.
  • Listen for a tone to confirm that the camera successfully recognized a command.
  • Change the wake word if you have more than one Garmin® device with voice control features.
Turning Voice Control On or Off
  • Select DownMenu > Voice Control > Settings > and select an option.
Via the Garmin Drive app4 when your dash cam is paired and connected to your compatible smartphone:
  • From the device settings menu, select Voice Commands, and select an option.
4Garmin Dash Cam™ 54, Garmin Dash Cam™ 55, and Garmin Dash Cam™ 65W driving recorders use the VIRB® Mobile App.  Voice Control must be enabled/disabled via the device menu.
For additional info on Voice Control see the owner's manual for your dash camera.
Related
