Viewing Hunting Management Units for the eTrex 20(x), 22x, 30(x), 32x
Hunting Management Units (HMU) will not be turned on by default when the HuntView Plus is installed on the eTrex® 20, 20x, 22x, 30, 30x, or 32x outdoor handheld. Instructions for enabling the mapping are below as well as some helpful tips for viewing the Hunting Management Units on the Map page of the handheld.
Things to Keep in Mind
Hunting Management Units (HMU) have multiple names depending on the state chosen and may be displayed as Game Management Units (GMU), Wildlife Management Units (WMU), or Hunting Zones.
All Hunting Management Units are show with green lines if multiple units are selected at the same time it may be difficult to view the data.
Only Units available for the state will be shown. For example, there will not be an option for alligators in Montana.
Some states do not group all species into specific units. For example, Oregon has 4 units: Duck, Goose, Fall Turkey, and all other species are grouped together under WMU.
The unit number will display at the top of the Map page if the area is highlighted.
Enabling Hunting Management Units
Open the Map page.
Press menu.
Select Setup Map.
Select HMU Setup.
Select the State.
Select the Unit(s) to view.
Press back until you return to the Map page.
The Hunting Management Unit(s) chosen should be visible on the Map page. You may have to zoom in or out depending on your view level.
Tips for Viewing Hunting Management Units on a Handheld Device
HuntView Plus maps have a lot of information. Quite often with Hunting Management Units enabled the Map page on the handheld may become very difficult to read.
Only enable the Hunting Management Unit currently needed.
Disable other map information from HuntView Plus mapping.
Open the Map page.
Press menu.
Select Setup Map.
Select Map Information.
Select a map, then select Disable. Repeat for any additional maps you wish to disable.
TIP: It is recommended to have at least the basemap enabled with the HMU mapping.
