(2021) Service Advisory 2129: Inconsistent navigator selection of altitude constraints for some waypoints common to STARs and Instrument Approach Procedures
PRODUCTS AFFECTED:
Garmin Pilot iOS, GTN 650/725/750, GTN Xi, G900X, G950, G950NXi, G1000, G1000NXi, G2000, G3000, and G5000 products are affected.
ISSUE:
In some cases, a Standard Terminal Arrival (STAR) Procedure and Instrument Approach Procedure (IAP) have a common waypoint marking the transition from one procedure to the next. The altitude/speed constraints for that waypoint, published for each procedure, may not be consistent. In these cases, the system loads the altitude/speed constraint from the IAP into the flight plan. This may not be the most appropriate altitude/speed.
ACTION:
When briefing STAR and Approach Charts, identify waypoints common to both. When these common waypoints mark the termination of the STAR and the beginning of the IAP, note the altitude and speed constraints for those waypoints on each chart. When discrepancies exist, ensure the Garmin Navigator has selected the desired altitude/speed constraint from the database for that waypoint. If necessary, change the loaded altitude/speed constraint as dictated by information on the published charts.
RESOLUTION:
Improvements in future software releases will attempt to better reconcile the STAR and IAP altitude/speed constraints and make occurrences of this issue less likely. However, improved software will not eliminate the need for careful review of the flight plan waypoints.
