SD Card Sizes for Garmin OEM Devices
A Garmin OEM device can use the maximum card size listed in the tables below.
If you have a Garmin navigation system built into your vehicle, see related content below for information about SD memory card size limitations.
Important Information:
  • When using a card with a larger capacity, if there are too many files and/or large files on the card, the device may draw maps more slowly
  • When updating the maps on a device, an SD card with at least 4 GB of space must be used
Select your device series in this list, or locate your device model in the following tables.
Aston Martin
Model
Maximum Capacity
Card TypeClass
Aston Martin GVN 54
 8 GB
SD
Class 2 to 10
Back to Top
BMW
The BMW nüvi® 350 and nüvi® 360 can use an SD card larger than 2 GB, but will not be able to read files larger than 2 GB from the SD card. For information, see the FAQ Devices Unable to Read Files Larger than 2GB in Size.
Model
Maximum Capacity
Card TypeClass
BMW nüvi® 350
 32 GB
SD
Class 2 to 10
BMW nüvi® 360
 32 GB
SD
Class 2 to 10
BMW nüvi® 760
 32 GB
SD
Class 2 to 10
BMW nüvi® 765
 32 GB
SD
Class 2 to 10
BMW nüvi® 880
 8 GB
microSD
Class 2 to 10
BMW nüvi® 3490LM
 32 GB
microSD
Class 2 to 10
BMW nüvi® 3790T
 32 GB
microSD
Class 2 to 10
During a map update on the BMW nüvi® 350, nüvi® 360, and nüvi® 880, Garmin Express will not recognize a memory card inserted into the device. See the FAQ Garmin Express Prompts me to Select a Region I don't want During a Map Update for instructions on loading the full map update to these models.
Back to Top
BMW Motorrad
Model
Maximum Capacity
Card TypeClass
BMW Motorrad Navigator IV
 32 GB
microSD
Class 2 to 10
BMW Motorrad Navigator V
 64 GB
microSD
Class 2 to 10
BMW Motorrad Navigator VI
 64 GB
microSD
Class 2 to 10
BMW Motorrad Navigator Street
 32 GB
microSD
Class 2 to 10
BMW Motorrad zūmo® 550
 4 GB
SD
Class 2 to 10
BMW Motorrad zūmo® 760
 64 GB
microSD
Class 2 to 10
64 GB cards will often be labeled SDXC (Extended Capacity). SD, SDHC and SDXC cards must be formatted as FAT32. If you are using a 64 GB card and your computer does not allow you to format it as FAT32, it is recommended to use a 32 GB card instead.  See  Using a 64 GB microSD/SD Memory Card
During a map update on the BMW Motorrad zūmo® 550, Garmin Express will not recognize a memory card inserted into the device. See the FAQ Garmin Express Prompts me to Select a Region I don't want During a Map Update for instructions on loading the full map update to these models.
Back to Top
Can-Am BRP
Model
Maximum Capacity
Card TypeClass
Can-Am BRP nüvi® 500
 32 GB
microSD
Class 2 to 10
Can-Am Spyder zūmo® 550
 4 GB
SD
Class 2 to 10
Can-Am Spyder zūmo® 590
 32 GB
microSD
Class 2 to 10
Can-Am Spyder zūmo® 660
 32 GB
microSD
Class 2 to 10
During a map update on the Can-Am Spyder zūmo® 550, Garmin Express will not recognize a memory card inserted into the device. See the FAQ Garmin Express Prompts me to Select a Region I don't want During a Map Update for instructions on loading the full map update to these models.
Back to Top
Chrysler
Model
Maximum Capacity
Card TypeClass
Chrysler nüvi® 255
 32 GB
SD
Class 2 to 10
Back to Top
Ducati
Model
Maximum Capacity
Card TypeClass
Ducati zūmo® 350LM
 32 GB
microSD
Class 2 to 10
Ducati 390LM
 32 GB
microSD
Class 2 to 10
Ducati zūmo® 395LM
 64 GB
microSD
Class 2 to 10
Back to Top
Ford
The Ford nüvi® 360 and nüvi® 680 can use an SD card larger than 2 GB, but will not be able to read files larger than 2 GB from the SD card. For information, see the FAQ  Devices Unable to Read Files Larger than 2GB in Size
Model
Maximum Capacity
Card TypeClass
Ford nüvi® 200
 32 GB
SD
Class 2 to 10
Ford nüvi® 260W
 32 GB
SD
Class 2 to 10
Ford nüvi® 360
 32 GB
SD
Class 2 to 10
Ford nüvi® 680
 32 GB
SD
Class 2 to 10
Ford nüvi® 760
 32 GB
SD
Class 2 to 10
Ford nüvi® 780
 32 GB
SD
Class 2 to 10
Ford StreetPilot® C550
 4 GB
SD
Class 2 to 10
During a map update on the Ford nüvi® 360 and nüvi® 680, Garmin Express will not recognize a memory card inserted into the device. See the FAQ Garmin Express Prompts me to Select a Region I don't want During a Map Update for instructions on loading the full map update to these models.
Back to Top
Harley Davidson
Model
Maximum Capacity
Card TypeClass
Harley Davidson Road Tech zūmo® 550
 4 GB
SD
Class 2 to 10
Harley Davidson Road Tech zūmo® 590LM
 32 GB
microSD
Class 2 to 10
Harley Davidson Road Tech zūmo® 660
 32 GB
microSD
Class 2 to 10
Harley Davidson Road Tech zūmo® 665
 8 GB
microSD
Class 2 to 10
During a map update on the Harley Davidson Road Tech zūmo® 550 and zūmo® 665, Garmin Express will not recognize a memory card inserted into the device. See the FAQ Garmin Express Prompts me to Select a Region I don't want During a Map Update for instructions on loading the full map update to these models.
Back to Top
Honda
The Honda nüvi® 360 can use an SD card larger than 2 GB, but will not be able to read files larger than 2 GB from the SD card. For information, see the FAQ  Devices unable to read files larger than 2GB in size
Model
Maximum Capacity
Card TypeClass
Honda nüvi® 350
 32 GB
microSD
Class 2 to 10
Honda zūmo® 550
 32 GB
microSD
Class 2 to 10
During a map update on the devices in this table, Garmin Express will not recognize a memory card inserted into the device. See the FAQ Garmin Express Prompts me to Select a Region I don't want During a Map Update for instructions on loading the full map update to these models.
Back to Top
Hyundai
The Hyundai nüvi® 360 can use an SD card larger than 2 GB, but will not be able to read files larger than 2 GB from the SD card. For information, see the FAQ  Devices unable to read files larger than 2GB in size.
ModelMaximum CapacityCard TypeClass
Hyundai nüvi® 260W 32 GBSDClass 2 to 10
Hyundai nüvi® 360 32 GBSDClass 2 to 10
Hyundai nüvi® 760 32 GBSDClass 2 to 10
During a map update on the Hyundai nüvi® 360, Garmin Express will not recognize a memory card inserted into the device. See the FAQ Garmin Express Prompts me to Select a Region I don't want During a Map Update for instructions on loading the full map update to these models.
Back to Top
Mazda
The Mazda nüvi® 680 can use an SD card larger than 2 GB, but will not be able to read files larger than 2 GB from the SD card. For more information, see the FAQ  Devices unable to read files larger than 2GB in size.
Mazda nüvi® 680 32 GBSDClass 2 to 10
Mazda nüvi® 760 32 GBSDClass 2 to 10
During a map update on the Mazda nüvi® 680, Garmin Express will not recognize a memory card inserted into the device. See the FAQ Garmin Express Prompts me to Select a Region I don't want During a Map Update for instructions on loading the full map update to these models.
Back to Top
Mercedes
Mercedes nüvi® 760 32 GBSDClass 2 to 10
Mercedes StreetPilot® C530 4 GBSDClass 2 to 10
Mercedes StreetPilot® C550 4 GBSDClass 2 to 10
Back to Top
MINI
The MINI nüvi® 360 can use an SD card larger than 2 GB, but will not be able to read files larger than 2 GB from the SD card. For information, see the FAQ  Devices unable to read files larger than 2GB in size
Model
Maximum Capacity
Card TypeClass
MINI nüvi® 360
 32 GB
SD
Class 2 to 10
MINI nüvi® 1260
 32 GB
microSD
Class 2 to 10
MINI nüvi® 2497LM
 32 GB
microSD
Class 2 to 10
MINI nüvi® 3790LM
 32 GB
microSD
Class 2 to 10
During a map update on the MINI nüvi® 360, Garmin Express will not recognize a memory card inserted into the device. See the FAQ Garmin Express Prompts me to Select a Region I don't want During a Map Update for instructions on loading the full map update to these models.
Back to Top
Mopar
Model
Maximum Capacity
Card TypeClass
Mopar nüvi® 205T
 32 GB
SD
Class 2 to 10
Mopar nüvi® 265WT
 32 GB
SD
Class 2 to 10
Mopar nüvi® 880
 8 GB
microSD
Class 2 to 10
Mopar nüvi® 1250
 32 GB
microSD
Class 2 to 10
Mopar nüvi® 1350
 32 GB
microSD
Class 2 to 10
Mopar nüvi® 1490T
 32 GB
microSD
Class 2 to 10
During a map update on the Mopar nüvi® 880, Garmin Express will not recognize a memory card inserted into the device. See the FAQ Garmin Express Prompts me to Select a Region I don't want During a Map Update for instructions on loading the full map update to these models.
Back to Top
Nissan
Model
Maximum Capacity
Card TypeClass
Nissan nüvi® 550
 32 GB
microSD
Class 2 to 10
Nissan nüvi® 750
 32 GB
SD
Class 2 to 10
Nissan nüvi® 760
 32 GB
SD
Class 2 to 10
Back to Top
Polaris
Model
Maximum Capacity
Card Type
Class
zūmo® 665
 8 GB
microSD
Class 2 to 10
During a map update on the zūmo® 665, Garmin Express will not recognize a memory card inserted into the device. See the FAQ Garmin Express Prompts me to Select a Region I don't want During a Map Update for instructions on loading the full map update to these models.
Back to Top
Suzuki
Model
Maximum Capacity
Card TypeClass
Suzuki nuLink! 1690
 32 GB
microSD
Class 2 to 10
Suzuki nuLink! 2390
 32 GB
microSD
Class 2 to 10
Suzuki nüvi® 750
 32 GB
SD
Class 2 to 10
Suzuki nüvi® 760
 32 GB
SD
Class 2 to 10
Suzuki nüvi® 765
 32 GB
SD
Class 2 to 10
Suzuki nüvi® 2360LT
 32 GB
microSD
Class 2 to 10
Back to Top
Toyota
Model
Maximum Capacity
Card TypeClass
Toyota nüvi® 260W
 32 GB
SD
Class 2 to 10
Toyota nüvi® 350
 32 GB
SD
Class 2 to 10
During a map update on the Toyota nüvi® 350, Garmin Express will not recognize a memory card inserted into the device. See the FAQ Garmin Express Prompts me to Select a Region I don't want During a Map Update for instructions on loading the full map update to these models.
Back to Top
Volkswagen
Model
Maximum Capacity
Card TypeClass
Volkswagen nüvi® 755
 32 GB
SD
Class 2 to 10
Volkswagen nüvi® 765
 32 GB
SD
Class 2 to 10
Back to Top
Volvo
Model
Maximum Capacity
Card TypeClass
Volvo nüvi® 760
 32 GB
SD
Class 2 to 10
Volvo nüvi® 765
 32 GB
SD
Class 2 to 10
Volvo nüvi® 860
 8 GB
microSD
Class 2 to 10
Volvo nüvi® 3490
 32 GB
microSD
Class 2 to 10
Volvo nüvi® 3760
 32 GB
microSD
Class 2 to 10
Volvo nüvi® 3790
 32 GB
microSD
Class 2 to 10
During a map update on the Volvo nüvi® 860, Garmin Express will not recognize a memory card inserted into the device. See the FAQ Garmin Express Prompts me to Select a Region I don't want During a Map Update for instructions on loading the full map update to these models.
Back to Top
Related
