How to Improve the quatix 6 Battery Life
If the quatix 6 is requiring a charge more frequently than expected, it could be due to usage or settings. Below is a list of functions that could cause the battery to drain faster than anticipated. For instructions on enabling or disabling these, visit the "Customizing Your Device" section in the owner's manual.
Using Power Manager to Improve Battery Life
The quatix 6 series brings new features that quickly control battery usage. The Power Manager, featuring Battery Saver and Power Modes, allows customization and save key settings that affect battery consumption to improve battery life. When looking to get the most out of battery life, start by looking into the Power Manager. To learn more about Power Manager, visit " Understanding the fēnix 6 Series Power Manager."
Your watch can perform a variety of functions, and any function the watch performs will require some power from the battery. Some functions, and how often you use them, will require more battery than others.
Why is My Watch Battery Draining Quickly?
If your watch has a shortened battery life, here are some troubleshooting steps we recommend.
Fully charge your watch to see if the issue has been resolved.
If your watch continues to drain battery quickly, check any recently adjusted settings that could contribute to a higher battery use. For help adjusting watch settings, see the
How Can I Get More Battery Life?
section below.
If your battery is being used faster than expected, or not lasting as long as it used to, read the information below to learn about settings and features that have a greater impact on battery usage.
Adjust Settings
The default settings for your watch were configured to balance performance with battery life. Changed settings may be the cause of increased battery drain. If you forgot the settings you changed, you can restore the default settings for your watch. For help see,
Reset Default Settings
NOTE: Settings for the options listed below are located in the watch menu. Not all watches will support all listed features. Refer to your owner's manual for feature compatibility, and exact setting location.
Pulse OX: Using All-Day Acclimation or During Sleep modes with the pulse oximeter will use the battery at a higher rate. To conserve battery life, it is recommended to set the acclimation mode to Manual. The watch will only analyze your oxygen saturation when you view the pulse oximeter widget.
Backlight: How bright the backlight is set, and how often it comes on, can use battery more quickly or less quickly. Having backlight set at 100% will use a lot of battery while the backlight is on. The manual backlight setting uses the least energy, and some settings, such as gesture, will use more battery.
GPS: When enabled you will see a higher battery use, which is why GPS tracking is only activated during activities or navigation.
Music: Controlling music being played on your phone, downloading music over Wi-Fi, and playing music stored on the watch will contribute to higher battery use. We recommend charging your watch while downloading music, if it supports this feature.
Bluetooth: Occasional text notifications and use of other connected features will drain far less battery than continually receiving texts, answering the phone, running a music player, or getting weather updates.
Connected Sensors: Additional connected sensors like HRM chest straps, power meters, or Bluetooth headphones all require additional power from the watch to stay connected.
Watch Face: Some watch faces, apps, widgets, and data fields may draw more power depending on how many things they do or whether they use GPS positioning or not.
Widgets: Some widgets update data when you select them, like weather. Widgets like Altimeter, Barometer, and Compass (ABC sensors) are always active.
Hold UP/MENU.
Select System.
Select Reset.
Select Reset Default Settings.
Press GPS to select Continue.
Select Yes.
If your watch is paired to your phone, you will need to pair the watch back to the phone after resetting. For help on pairing your watch to your phone, refer to your owner's manual. For additional resources on pairing your watch, see - Garmin Connect™ App Bluetooth Troubleshooting.
Clean Charging Contacts
Garmin recommends using a Garmin charging cable, and making sure the charging contacts on the watch and charging cable are free and clear of debris. For instructions on how to clean the charging contacts, see - Cleaning the Battery Contacts on a Rechargeable Garmin Watch.
Significant battery use can sometimes occur if an activity or another feature is left running in the background. See “Stopping an Activity” in your owner's manual for steps on how to stop an activity on your watch.
Otherwise, you can try the following steps to perform a power cycle:
Turning the Watch Off
Hold LIGHT button.
Select Power Off.
The watch will power off.
Turning the Watch On
Hold LIGHT button for three seconds.
The watch will power on.
Is Your Watch Battery Still Draining Quickly?
After attempting the above troubleshooting if you still see significant battery use, we recommend contacting Product Support to help determine what is using the battery.
Some information to help Product Support determine what might be using the battery more than expected:
What brightness is the backlight set to, and is Gesture enabled?
How often are you performing GPS activities, and how long are they?
Is Pulse Ox enabled? If so, what is it set to?
What is the battery estimate in days on a full charge, and how long does it take to completely drain the battery?
What kind of watch face are you using? Does it display current heart rate?
Some of the functions are redundant. For example, steps and activities are uploaded both through WiFi and the Bluetooth connection to the Garmin Connect Mobile application. If using the Garmin Connect Mobile app continuously, it may be a good idea to turn off the Auto Upload setting to help conserve battery power. The Storm Alert function of the Barometer when a smartphone updates local weather is another redundant battery drain. If the battery drain continues after making some settings changes, try returning the watch to factory defaults and seeing how long the battery lasts on a full charge without pairing it to the smartphone again. If the battery lasts like it used to, then the battery drain would result from customized settings on the watch or Bluetooth-connected features.
