Area Calculation Information for Garmin Outdoor Handhelds
The Area Calculation feature is a type of specialized track that once a designated area has been walked, the device will give a calculation total in square feet or square meters for that area.
The following handheld models offer the Area Calculation feature. Select your device below for instructions.
eTrex® 10 | eTrex® 20 | eTrex® 20x | eTrex® 22x | eTrex® 30 | eTrex® 30x | eTrex® 32x
Performing an Area Calculation
  1. Press menu twice to access the main menu.
  2. Select Area Calculation.
    NOTE: You may need to edit the main menu to add area calculation.
  3. Press Start.
  4. Travel the perimeter of the area.
  5. Select Calculate when finished.
Viewing Area Calculation From a Saved Track
  2. Select Track Manager.
  3. Select a saved track.
  4. Select View Map.
  5. Press menu.
  6. Select Review Track.
eTrex® SE | eTrex® Solar
  1. Select Area Calculation.
  2. Press OK to start calculation function.
  3. Travel the perimeter of the area.
  4. Press OK when finished.
  5. Select Save.
Viewing Area Calculation From a Saved Activity
  1. Select Saved.
  2. Select Activities
  3. Select a saved activity.
  4. Press OK.
  5. Select All Stats, then press Down Arrow to scroll down.
eTrex® Touch 25 | eTrex® Touch 35 | eTrex® Touch 35t
  1. Press Power Button to open the app drawer.
  3. Press Start.
Viewing Area Calculation From a Saved Activity or Track
  2. Select Activity History or Track Manager.
  3. Select a saved activity or track.
  4. Select Lowercase i.
GPSMAP® 62 | GPSMAP® 62s | GPSMAP® 62sc | GPSMAP® 62st | GPSMAP® 62stc
  1. Press MENU twice to access the main menu.
  3. Press Start.
  4. Select View Map.
  5. Press MENU.
GPSMAP® 64 | GPSMAP® 64s | GPSMAP® 64sc | GPSMAP® 64st | GPSMAP® 64sx | GPSMAP® 64csx | GPSMAP® 64x
  3. Press Start.
  4. Select View Map.
  5. Press MENU.
GPSMAP® 65 | GPSMAP® 65s
  3. Press Start.
  4. Select View Map.
  5. Press MENU.
GPSMAP® 66i | GPSMAP® 66s | GPSMAP® 66sr | GPSMAP® 66st
  3. Press Start.
  2. Select Recorded Activities or Saved Tracks.
GPSMAP® 67 | GPSMAP® 67i
  3. Press Start.
GPSMAP® 86i | GPSMAP® 86s | GPSMAP® 86sc | GPSMAP® 86sci
  3. Press Start.
Montana® 600 | Montana® 600t Camo | Montana® 650 | Montana® 650t
  1. Tap Arrow to open the app drawer.
  3. Press Start.
  4. Select View Map.
  5. Tap on the name of the track at the top of the screen.
Montana® 610 | Montana® 610t Camo | Montana® 680 | Montana® 680t
  3. Press Start.
Montana® 700 | Montana® 700i | Montana® 710 | Montana® 710i | Montana® 750i | Montana® 760i
  1. Select Home to access the main menu.
  3. Press Start.
Monterra®
  1. Select 6 dots in a circle to open the app drawer.
  3. Press Start.
  4. The area will be listed under INFO
Oregon® 200 | Oregon® 300
  1. Go to the main menu.
  3. Press Start.
  1. Go to the main menu,
  4. Select View Map.
Oregon® 400t | Oregon® 400c | Oregon® 400i | Oregon® 450 | Oregon® 450t
  3. Press Start.
  4. Select View Map.
Oregon® 550 | Oregon® 550t
  3. Press Start.
  4. Select View Map.
Oregon® 600 | Oregon® 600t | Oregon® 650 | Oregon® 650t
  1. From the home screen, open the app drawer by swiping bottom to top in portrait mode or left to right in landscape mode.
  3. Press Start.
Oregon® 700 | Oregon® 750 | Oregon® 750t
NOTE: The user interface on these devices is set to Activity Mode by default, but they can be changed to Classic Mode by going to the app drawer and selecting Setup > System > Mode.
  1. Open the app drawer.
    • Activity Mode: Press Power Button.
    • Classic Mode: From the home screen, swipe bottom to top in portrait mode or left to right in landscape mode.
  3. Press Start.
Rino® 610 | Rino® 650 | Rino® 650t | Rino® 655t
  3. Press Start.
  4. Select View Map.
Rino® 700
  1. Press Menu Key twice to access the main menu.
  3. Press Start.
  4. Select View Map.
  5. Press Menu Key.
Rino® 750 | Rino® 750t | Rino® 755t
NOTE: The user interface on the Rino 750, 750t, and 755t is set to Classic Mode by default, but it can be changed to Activity Mode by going to the app drawer and selecting Setup > System > Mode.
  3. Press Start.
