The Button on My Varia RTL510 Is Stuck or Not Responding
Cycling over time can cause a build up of debris which may result in the button not functioning properly. To loosen dirt and grime from the button, please perform the following steps:.
Ensure the USB weather cap is in place.
Place the Varia under streaming warm water for about 10 seconds.
Remove it from the running water and press the button repeatedly a few times.
Rinse it again for about 10 seconds.
When the unit appears to be clean, remove it from the water and test the button to verify that it works correctly.
