Installing the Latest Software On the Descent Mk1
Keeping your software up to date will ensure that you get the best performance and latest features. Methods for updating software are described below.
For information on updating compatible mapping, see Related at the bottom of the page.
Installing Software Updates
Garmin Connect™ App
The Garmin Connect app will download software updates automatically behind the scenes while your device is connected to your mobile phone. Generally, any released updates will take up to a week to download before prompting to install on your dive computer.
To check or manually apply the update:
  1. Hold UP (middle left button) from the watch face.
  2. Select Settings.
  3. Select System.
  4. Select Software Update.
    • Ensure Auto Update is enabled. If necessary, press START/STOP (upper right button) to enable it.
  5. Select Update Available.
  6. Press DOWN (lower left button) to continue and apply the update.
Search for, and download, the Garmin Connect app in the application store for your phone to get started. For more information on the Garmin Connect app, see - Garmin Connect app on Garmin.com.
Garmin Express™ Software
Garmin Express software provides the ability to check for, and download, software updates each time you connect your device to the computer.
For information on downloading Garmin Express software and using it to update your device, see - Using Garmin Express to Update Your Watch's Software.
Software Update Details
We are frequently making improvements and even new features with the latest software updates. For a complete list of changes, click on the software version change logs below.
16.10
  • Improved the in-dive experience to perform additional status checks of the depth sensor
Previous Software Version Change Logs
16.00
  • [In-dive Change] - Fix CNS calculations at PO2 levels above 1.65
14.00
  • Added the Dive Setup > No Fly setting, to allow choosing between DAN's no-fly guidance and the previous flat 24-hour timer.
  • Added a new page to the Surface Interval widget to allow seeing detailed no-fly information, including when the timer will expire.
  • Dive logs can now be deleted like other activities. Deleting a dive may cause dive numbers to get out of sync until the next sync with Connect.
  • Updated to include changes from fenix 5X through version 25.00: fenix 5X software version 25.00.
12.00
  • [IN-DIVE CHANGE] Added the current gas to the Switch Gas list, with a checkmark to indicate it’s the active gas.
  • Swapped the positions of OTU and N2/He load on the Surface Interval widget.
  • Renamed Bottom Time to Dive Time in the dive log. This update will occur in Garmin Dive/Connect in the future as well.
  • Fixed an issue where a dive alert that was active when a dive saved wouldn’t get cleared correctly and could appear the next dive.
  • Fixed an issue with the update rate of the altitude barometer that could cause stair-stepped elevation graphs.
  • Fixed a potential battery drain issue after disconnecting an inReach device.
  • Fixed average depth in Gauge mode failing to update, if the watch was rebooted mid-dive.
  • Fixed an issue with Connect IQ menus with dynamic numbers of items.
  • Updated to include changes from fenix 5X through version 21.00: fenix 5X software version 21.00.
10.40
  • Fixed a crash that can occur when changing the depth of an automatic CCR setpoint switch.
  • Fixed ascent rate being calculated incorrectly when updating at a rate faster than once per second, such as in Apnea activities.
  • Fixed how Bottom Time is rounded in the dive log details to match the Garmin Dive app.
10.20
  • Fixed display issue with disclaimer text
10.10
  • IN-DIVE CHANGE: Changed the behavior of dive compass Set to Recip., Set to 90L, and Set to 90R to set the new heading offset from the original heading instead of the current heading.
  • IN-DIVE CHANGE: Added the ability to hold BACK to return to the first dive screen.
  • IN-DIVE CHANGE: Added “Bail-out to Diluent” option if no open-circuit cases are set up in a CCR dive.
  • IN-DIVE CHANGE: Fixed an issue where, in a CCR dive, the PO2 was being incorrectly calculated as the maximum of the diluent's PO2 or the current setpoint. This error could occur when diving in a situation where a diluent flush would actually raise the PO2 of the loop.
  • IN-DIVE CHANGE: In the CCR app, the current PO2 value will now blink yellow if the diluent PO2 is below 0.18.
  • Added a setting to enable the UP key while in-dive (Dive Setup > UP Key).
  • Added the ability to set an initial surface interval when computing NDL in the Plan Dive app.
  • Added Fenix 5X improvements from software version 13.30 to 19.10 - https://www8.garmin.com/support/download_details.jsp?id=11429
  • Increased the maximum number of apps from 40 to 60.
  • Improved the power-on check page to give more useful information.
  • Fixed an issue where changing the tap-to-scroll setting wouldn't take effect if changed from a dive pre-check.
  • Fixed an issue where setting up the device by pairing with Connect wouldn't respect the Connect account's metric/statute setting.
  • Fixed showing the Save Waypoint menu for non-dive activities.
  • Fixed the depth graph's x-axis to include surface time - this is most obvious on Apnea activities.
  • Fixed showing bad data in the Dive Log for Apnea dives when trued up from Connect.
  • Fixed an issue where the device was displaying incorrect time for Brazil within the Alternate Time Zones widget.
  • Brought in CIQ security updates.
 8.00
  • Fixed not being able to select a CCR setpoint ending in .00
  • Fixed the dive compass menu to respect the true/magnetic north setting
  • Improved source for all temperature readings
  • Includes Fenix 5X improvements between software version 10.20 to 13.30 -https://www8.garmin.com/support/download_details.jsp?id=11429
6.00
  •  IN-DIVE CHANGES:
    • Added a new in-dive menu that replaces the Backup Gas menu (in the Single-Gas app) and the Switch Gas menu (in the Multi-Gas app).
      • The gas switching menu is now accessible from the first item in this new menu ("Gas").
    • Added the ability to edit some settings during a dive. These settings include:
      • Deco PO2
      • Conservatism
      • Setpoints (in the CCR app)
    • Added the ability to add new gas mixes during a dive.
      • Access this new feature by selecting "Add New" in the gas switching menu.
      • Gases added while the dive timer is running are only available during that dive.
      • Open-circuit gases are added as backups and won't be included in TTS calculations unless you switch to them.
      • All closed-circuit diluents are included in TTS calculations.
      • Between gases defined pre-dive and gases defined in-dive, the total number of gas "slots" has been increased to 18.
    • Improved the consistency of the compass and time-of-day dive screens by flipping the positions of NDL/TTS and Depth to match the main dive screen.
    • Fixed an Apnea issue introduced in 4.00 where the faster depth updates were not reflected in the ascent/descent rate.
  • OTHER DESCENT SPECIFIC CHANGES:
    • Added Closed Circuit Rebreather app.
    • Added new breathing gas management system.
      • Gases are now split by app: Single-gas, Multi-gas, and CCR.
      • The existing gas list has been copied to both Single-gas and Multi-gas.
      • The maximum number of gases per-app has been increased from 6 to 12.
      • The Plan Dive app now has the option to overwrite either the Single-gas or Multi-gas gas list. If the plan has more than one enabled gas, it can only be applied to the Multi-gas list.
      • Travel Gas is now chosen by selecting an Enabled gas and choosing "Set as Travel Gas." Deleting that gas or selecting "Unset as Travel Gas" will set the travel gas back to the bottom gas.
      • Deco and backup gases are now ordered by %O2.
    • Added Pool Mode
      • Added a new Controls Menu item to enable/disable Pool Mode (Settings > Controls > Add New > Pool Mode).
      • When Pool Mode is active, dives are not saved to the dive log.
      • When Pool Mode is active, tissue load is tracked as normal (for gas dives), gauge and deco lockouts apply, and no-fly and surface interval timers continue to function.
      • If it is still active, Pool Mode will turn off automatically each night at midnight.
    • Added the ability to save a dive's Entry and Exit points (if known) as saved locations. In the dive log, choose a dive and select Save Location.
    • Added the ability to edit the Apnea surface interval alert while on the surface interval pages.
    • Added the minimum temperature of the last dive to the main Apnea surface interval page.
    • Improved Navigate app when navigating to a saved dive activity. You now have the option of navigating to either the entry or exit point, if available.
    • Improved Conservatism menu to show the gradient factors of the quick settings (low/medium/high).
    • Improved the dive log to show Time In and Time Out.
    • Fixed a potential issue where switching from At Depth to Always On backlight via the dive pre-check might not take effect until the next dive.
  • CHANGES BROUGHT IN FROM FENIX 5X:
    • Updated fēnix 5X base from 7.60 -> 10.10. Major new features include:
      • Added the Sunrise & Sunset widget.
      • Added the Alternate Time Zones widget.
      • Added support for Physio TrueUp. Physio TrueUp syncs activities done on other Garmin devices, allowing your device to more accurately reflect your training status and fitness.
        NOTE: Dive activities are not yet supported and will show up with incomplete data.
    • Added support for Garmin Xero Bow Sight.
    • Added support for Garmin inReach Mini.
    • Added support for REM sleep phase detection.
      NOTE: This is not turned on in Connect yet.
    • Added the Kayak app
    • Added support for Connect IQ SDK v3.0
    • Added support for canned text replies when responding to text messages (Android only)
    • Added abnormal heart rate alerts
5.15
  • Improved the CCR in-dive menus to prioritize setpoint switching and bailing out
    • (Gas, CCR, & Gauge apps) The main dive menu is now also accessible from the Time of Day dive screen
    • (CCR app) The compass menu now has a Switch to OC bailout option.
    • (CCR app) When in CC Mode, Switch Setpoint and Switch to OC are now the top two menu options.
  • Fixed being able to add dive screens to non-dive apps.
 4.00
  • IN-DIVE CHANGE: Improved NDL to show as '99+' instead of '--:--' when greater than 99:59.
  • IN-DIVE CHANGE: Improved metric depth display when over 100m to show without a decimal point.
  • IN-DIVE CHANGE: Improved Apnea and Apnea Hunt apps to update the depth display more quickly (4x/second).
  • IN-DIVE CHANGE: Improved behavior of safety stops:
    **Previously, the safety stop timer started counting down at 15 feet. This has been changed to 20 feet (6m).
    **Previously, the safety stop timer continued counting down while in the range of 10-20 feet. This has been expanded to 7-23 feet (2-7m)
    **Previously, the watch would require a return to the start depth (15 feet) to resume a paused safety stop timer. This requirement has been removed.
    **Previously, if NDL was surpassed while below 35 feet, the watch would cancel the safety stop in favor of normal decompression stops. Now, if the deco commitment is cleared prior to ascending to 23 feet (7m), there will still be a safety stop scheduled for 20 feet (6m).
    **Previously, the watch showed the 'Safety stop started!' popup every time the safety stop timer resumed counting down. It will now only show the first time.
    IN-DIVE CHANGE: Disabled vibration for Apnea Hunt app.
  • Added travel gas setting for Multi-Gas app. If more than one gas is Enabled, you can choose a travel gas. This is the default gas used when starting a multi-gas dive and is indicated by a downward angled arrow on the Multi-Gas precheck. This does not affect other dive apps.
  • Added list of gas switches to dive log entries.
  • Added ability to turn off surface GPS per dive type. This can be used to save battery when diving indoors, for example. This setting is located at Settings > Activities & Apps > (Dive App) > (Dive App) Settings > GPS.
  • Added ability to set Deco PO2 up to 2.00. Please dive within your limits.
  • Added support for Rep Counting during Strength and Cardio workouts which can be created on Garmin Connect Web and Garmin Connect Mobile. To enable Rep Counting, ensure that Settings > Activities & Apps > Strength > Rep Counting is enabled. Start the timer to automatically count reps during sets. Press the lap key to rest between sets. You can edit your last set's number of reps and weight during a rest period. Press the lap key to advance to the next set.
  • Added support for manual calibration of the Barometer. (Settings > Sensors & Accessories > Barometer > Calibrate).
  • Added support for Hourly Alerts. (Settings > System > Time > Alerts > Hourly).
  • Improved dive planner to explicitly list the descent stage. It will also use the new travel gas setting, if set.
  • Improved dive planner to show steps in red if the gas mix is over its MOD.
  • Improved NDL planner to show '99+' instead of '--:--' when greater than 99:59.
  • Improved surface interval to begin counting at the beginning of the End Dive Delay.
  • Improved dive log to exclude End Dive Delay in total time. This is now listed as 'Bottom Time'. This will not be recalculated for dives prior to this update.
  • Improved dive log to show more precise surface interval times for intervals under 3 days.
  • Improved display of bottom time to exclude milliseconds.
  • Improved display of G2 map icons.
  • Fixed a potential issue where dive entry/exit positions would not reset correctly.
  • Fixed dive planner using the previous dive's water density setting instead of the current setting.
  • Fixed adjusting conservatism after a dive not affecting tissue load percentages.
  • Fixed compass not being able to finish calibration after being exposed to a strong magnet.
  • Fixed connectivity issue with certain Huawei phones.
Related
