Navigational Avoidances on Garmin Automotive Devices
Garmin devices have an Avoidance menu where you can select various options that will adjust how your device routes you. Items with a check mark beside them will be avoided whenever possible.
A Detailed Video Tutorial Discussing Route Settings is Available Below.
To Locate the Avoidance Menu:
- Touch Settings
- Touch Navigation
- Touch Automobile
- Touch Avoidances
- Touch the desired Avoidance to enable it
Repeat the steps above to disable the checked Avoidance.
Available Avoidances:
- U-Turns – The U-Turns avoidance will avoid taking you on a route that requires a U-turn
- Highways or Motorways – The Highways or Motorways avoidance will avoid highways, interstates, freeways, motorways, and other major routes
- Toll Roads or Tolls and Fees – The Toll Roads or Tolls and Fees avoidance will avoid toll roads and certain specified congestion zones
- Traffic – The Traffic avoidance will route you around traffic problems if a quicker route is available, provided you are using a traffic receiver with an active traffic subscription
- Disabling the traffic avoidance does not disable traffic alerts from appearing on the device; however, it will not take the reported traffic incident into account when calculating routes.
- Ferries – The Ferries avoidance will avoid taking you on a route that requires a ferry crossing
- Carpool Lanes or Car Share Lanes – Avoids lanes designated specifically for carpooling sometimes referred to as High-occupancy vehicle (HOV) lanes
- Unpaved Roads – The Unpaved Roads avoidance will avoid taking you on unpaved roads
Note that devices will only avoid selected items when it is possible. For example, if you have U-Turns selected as an avoidance the device may still direct you to make a U-Turn if an alternate route is not available.
