Pairing the Garmin DriveSmart 65 with Amazon Alexa to the Garmin Drive App
To use the Garmin DriveSmart™ 65 with Amazon Alexa GPS navigator with a smartphone and Alexa features, it must be paired with a smartphone using the Garmin Drive™ app
Installing Garmin Drive App
First, it is necessary to install the free Garmin Drive app to your compatible smartphone. For information on compatible mobile platforms and automotive devices, see the FAQ Garmin Drive App Compatibility and Availability
Once you have confirmed that your phone and automotive device are able to communicate via the Garmin Drive app, the next step is to download the app to your phone. For steps, see the FAQ Installing the Garmin Drive App
To Pair the Garmin DriveSmart 65 with Amazon Alexa Device to the Garmin Drive App, Select your Phone's Operating System Below:
Android
1. Open the Garmin Drive app
  • You may need to first enable your phone's Bluetooth
  • Refer to the owner's manual for your phone if you are not sure how to enable Bluetooth
2. In the Drive app, if prompted, check the agree to the terms and touch Next
Drive Android Agree to the terms
3. Agree to the Warning
Drive Android Agree to Warning
4. Touch Navigation Device in the Garmin Drive app
Drive Android Select Your Device
5. On the Garmin device, touch Settings
6. Touch Wireless Networks
7. If no checkmark is present, check the box next to Bluetooth
8. Touch Pair when prompted on your phone
Android DS 65 AA Pair Message
9. Touch Yes if prompted on the Garmin device
10. Touch OK if prompted
11.  If prompted, touch Continue to agree to the Privacy Policy:
Android Personal Data
12. Touch Sign In. If you don't have an account touch Create Account
Android Drive Sign in
13. Pairing is now complete. Touch Continue to start the setup of the Alexa features.
Android You are now paired
14. Touch Continue for audio setup
Android Play Audio via bluetooth aux
15. Touch Yes or No depending on if you use Bluetooth to connect your smartphone to your vehicle or not
 Android Bluethooth to vehicle Y_N
16.  If you selected 'No' to Bluetooth connection with your car, touch Continue and proceed to step #22 below.
Drive app Aux Cable
17. If you selected 'Yes' and can play music from your phone to your vehicle
(You will need to have your phone connected with your vehicle via Bluetooth to complete the calibration).
Android Can you play music
18. Touch Continue to calibrate the Bluetooth audio
Android Calibrate bluetooth
19. Touch OK to start the audio calibration if prompted.
Android Connect your phone to vehicle
20. Touch Play Test Sound
  • Allow permission for Drive to record audio if prompted.
Android Play Test Sound
21. Touch Continue when audio setup is complete
Configuring audio
Audio Complete
 22. Touch Sign In with Amazon
  • Follow the prompts to sign into your Amazon account or Create an Amazon account and allow Drive app access to voice services.
  • NOTE: Signing into an Amazon Alexa account (activating Alexa) is required in the set up process of the Garmin Drive app. There would not be any way to disable the feature other than to remove the device from the Garmin Drive app or disable the Bluetooth pairing between the phone and the device.
  Amazon Alexa Sign In
23. Touch Next
 Amazon Alexa Next
24. Follow the prompts to set or skip Notification Permissions for:
  • Smart Notifications
Smart Notifications
  • Display Media Permission
Display Media
25. The device will now be ready to use in the Garmin Drive app
  DriveSmart connected in Drive app
Apple
1. Open the Garmin Drive app on your phone and set your phone to Find Me/Discoverable mode
Note: If you are not sure how to set your phone to Find Me/Discoverable mode, refer to the owner's manual or documentation that came with the cell phone.
2. On the Garmin device, touch Settings
3. Touch Wireless Networks
4. If no checkmark is present, check the box next to Bluetooth
5. In the Drive app if prompted, switch the toggle on to agree to the terms and touch Next
  • Allow permissions for Bluetooth and notifications if prompted.
iPhone License Agree
6. Touch Agree
iPhone Agree
7. Touch Navigation Device
8. Touch Find Garmin Device
Iphone Find device
9. Touch the name of the Garmin device from the list of compatible Bluetooth devices in the area
Select an accessory Drive app
10. Touch Yes, if prompted on the Garmin device
11. Touch OK, if prompted
12. Touch Pair on the phone, if prompted
Iphone touch pair
13. Touch Continue
Iphone continue
14. Touch Sign In. If you don't have an account touch Create Account
Iphone account
15. Pairing is now complete, click Continue to start the setup of the Alexa features
Iphone Let's set it up
16. Touch Continue for audio setup.
17. Touch Yes or No depending on if you use Bluetooth to connect your smartphone to your vehicle or not
18. If you selected 'No' to Bluetooth connection with your car, then touch Continue and proceed to  step #23 below
Drive app Aux Cable
19. If you selected Yes, and can play music from your phone to your vehicle, touch Yes to calibrate the Bluetooth audio.
  • You will need to have your phone connected to your vehicle via Bluetooth to complete the calibration.
20. Touch Continue
21.  Touch Play Test Sound
  • Allow access to microphone if prompted
22.  Touch Continue when the audio setup is complete.
Audio Complete
 23. Touch Sign In with Amazon
  • Follow the prompts to sign into your Amazon account or Create an Amazon account and allow Garmin Drive app access to voice services.
24. Touch Next
Amazon Alexa Next
25. Touch Enable Location Permissions or Skip for Now
Iphone location permission
26. The device will now be ready to use in the Garmin Drive app
Related
