Create a Custom Start Up Message on an Edge Cycling Computer
Many Edge cycling computers can display a customized welcome message on the startup splash screen. If you lose your Edge cycling computer, a custom start up message may help you get it back.
Custom Start Up Message on Edge device while powering up
Customizing the Start Up Text
Select your operating system below to display instructions:
Windows
  1. Connect the Edge to a computer with a USB data cable.
  2. Open File Explorer on your computer.
    Opening file explorer through start up menu
  3. Access the Garmin drive when it appears then open the Garmin folder.
    Opening the Garmin folder from the edge drive
  4. Locate the file named startup.txt.
    Finding the startup.txt file in the Garmin folder
  5. Drag the Startup.txt file to the desktop and open the file.
    Dragging the startup.txt file to the desktop
  6. Edit the message. Make note of the instructions on this file. The maximum number of characters is 256.
    Editing the line under the line indicated to type your message
  7. Save these changes by pressing Ctrl + S on your keyboard.
  8. Exit the Notepad window.
  9. Drag the edited startup.txt file back to the Garmin folder and select "Replace the file in the destination".
    Dragging the startup.txt file back to the Garmin folder
After saving the file, the customized message will display on the device when powering on.
Mac
NOTE: Edge cycling computers with Media Transfer Protocol (MTP) require a Windows computer to access the Garmin Folder. For a list of MTP Edges, refer to Fitness and Outdoor Devices with Media Transfer Protocol.
  1. Connect the device to computer with a USB data cable.
  2. Once your Edge is recognized open the Garmin drive on the desktop of your computer.
    Mac desktop background with silver Garmin drive
    • Or, open the Finder application then access the Garmin drive.
      Animated GIF. Opening Finder then selecting the Garmin drive.
  3.  Open the Garmin folder. Set to view as List.
    Animated GIF. Open Garmin folder
  4. Click and drag the file named startup.txt to the Desktop background.
    Animated GIF. Drag and paste startup.txt file to desktop background
  5. Open the copied file named startup.txt and edit the message. Make note of the instructions on this file. The maximum number of characters is 256. In this window, you can adjust how many seconds your custom message displays.
    Animated GIF. Open and edit the startup message
  6. Exit the startup.txt window. It will automatically save your changes.
  7. Replace the original startup.txt file in the Garmin folder of the Edge device with the edited copy from the Desktop.
    Animated GIF. Drop startup.txt file copy into Garmin folder and replace original.
  8. Eject your Edge then unplug it from your Mac computer.
    Animated GIF. Eject Garmin drive on Mac
Compatible Edge Cycling Computers
Here is the list of Garmin Edge computers with customizable start up texts.
  • Edge® 510
  • Edge® 520 | Edge® 520 Plus
  • Edge® 530
  • Edge® 540 | Edge® 540 Solar
  • Edge® 800
  • Edge® 810
  • Edge® 820
  • Edge® 830
  • Edge® 840 | Edge® 840 Solar
  • Edge® 1000
  • Edge® 1030 | Edge® 1030 Plus
  • Edge 1040 | Edge 1040 Solar
  • Edge® 1050
  • Edge® Explore
  • Edge® Explore 2
  • Edge® Explore 820
  • Edge® Explore 1000
  • Edge® Touring
  • Edge® Touring Plus
Related
