Customizing Your Activity Profile List in Garmin Connect
Many Garmin® devices allow you to update what activity profiles display on the watch from within the Garmin Connect™ app. To see a list of available activity profiles that you can customize on your watch, follow the steps below.
NOTE: Some devices have a limit to the number of activity profiles that will display on the watch at one time.
  1. Open the Garmin Connect app on your smartphone.
  2. Select More (bottom right).
  3. Select Garmin Devices.
  4. Select your device.
  5. Select Activities, Activity Options, or Activities & Apps.
  6. Select Edit
  7. Select Plus or Minus to add or remove displayed activities.
  8. Select Done.
  9. Sync your device.
Once the sync is complete the activity profiles on your device will be updated.
If your device does not offer the ability to customize the activity profile list in Garmin Connect, see your owner’s manual for instructions for customizing your watch.
