Clarion M508 Software Update
M508 Improvements (8/8/2018)
USB bug fix
Bluetooth Handsfree calling bug fixes
Pandora bug fixes
MW1/MW3/MW6 compatibility
Other bug fixes
Estimated Update Time: 90 seconds
Introduction
NOTE: Do not perform this software update while operating the vessel/vehicle. Do not interrupt the power of the M508 during the update process. Remember to record all the “Settings” prior to performing the update process, as after the update the settings will be reset to the factory default.
Requirements
• A Windows PC with an internet connection and a Zip/Unzip program installed into it.
• A blank USB memory device with 256MByte or 4GByte maximum.
• Access to the USB port on the M508.
Preparation
Copy the “M508_V1.21.011_180529_HFP.MVA” file first to a blank USB memory device from your PC.
With the M508 powered on, insert the USB memory device into the USB port. The unit will automatically recognize the USB memory device and show “USB FW UPDATE”, press the volume knob to start update process.
M508 will display “USB FW UPDATING” during the updating process.
Once the process has been completed, remove the USB memory device from the M508.
NOTE: Do not interrupt the file transfer process. The M508 will automatically reboot when the file transfer is complete.
Confirm Result
NOTE: If the software versions does not match, please perform the software update again.
