Garmin Sonar Readings Show Differently From One Panoptix LiveScope System to the Next
Often users compare the setup of sonar equipment, and it doesn't always look the same on display. Some settings are chartplotter specific, and others are sonar specific. Settings can differ between units and software versions. Below is a list of settings to look, compare and adjust. See the owner's manual for steps on sonar settings .
Local to Chartplotter
The following settings are unique to each chartplotter:
Zoom
Gain
Pause
Color Scheme
Color Gain
Trails
Grid Overlay
Scroll History
On screen control
Compress Range
Overlay Data
Local to the LiveScope™ system (GLS™ 10 sonar module)
When changed at the GLS 10 level, the following settings will affect all networked chartplotters with the GLS 10 selected as the LiveScope source. GLS settings are unique to each GLS 10 unit.
Range
Transmit On / Off
TVG
Noise Reject
Install Depth
Stabilization
Compass Calibration
FOCUS
Restore Defaults**
*Overlay data setting affects all sonar pages on the chartplotter.
** Restore Defaults resets the local chartplotter settings from the device that initiates the reset and resets the GLS 10 setting for all GLS 10 units on the network. But not any local settings on the other chartplotter.
