Serial Number Location for Garmin Power Meter Pedals
The serial number for Rally™ and Vector™ power meter is located on the white barcode sticker, on the outside of the original box. If the original box has been discarded, you can obtain the Unit ID which can be used by Garmin Product Support to determine the serial number. Steps to do so can be found below.
NOTE: Serial number information is not printed on the pedals.
Rally XC200 Garmin Packaging
Below are general steps for locating the Unit ID. For specific steps, refer to your owner's manual.
  1. Make sure the Pedals are in Bluetooth range and active.
  2. Access the Menu of your device.
  3. Locate the screen where you add sensors.
  4. Select the pedals you have previously paired.
  5. Select Sensor Details (not applicable on all models).
  6. Select About.
  7. Select Power under Components (not applicable on all models).
  8. View the Unit ID/Serial Number.
