Automotive Device Not Detected by Garmin BaseCamp on a Windows Computer
USB communication issues can prevent your Garmin device from being detected by the BaseCamp™ software.
Verify Your Device Displays the Connection Icon
Most Devices will Display an Icon when Connected to a Computer
These icons vary, but some examples include:
Garmin devices plugged into a computer tower via USB cable
The Following Devices will not Display an Icon when Connected to a Computer
    • Arctic Cat G8 Display
    • Camper 785 & Traffic caravan and motorhome sat nav with camera
    • Camper 890 caravan and motorhome sat nav
    • Camper 895 caravan and motorhome sat nav
    • Camper 1090 caravan and motorhome sat nav
    • Camper 1095 caravan and motorhome sat nav
    • Garmin Catalyst™ Driving Performance Optimizer
    • dēzl™ 780LMT-S GPS navigator
    • dēzl™ LGV800 | dēzl™ OTR800 GPS navigators
    • dēzl™ LGV810 | dēzl™ OTR810 GPS navigators
    • dēzl™ LGV1000 | dēzl™ OTR1000 GPS navigators
    • dēzl™ LGV1010 | dēzl™ OTR1010 GPS navigators
    • dēzlCam™ 785 LMT-S GPS navigator with camera
    • Garmin fleet™ 770 management
    • Garmin fleet™ 780 GPS management
    • Garmin fleet™ 790 GPS management
    • Kawasaki RIDGE 8" Tread Display
    • Overlander® GPS navigator
    • RV 785 & Traffic RV navigator with camera
    • RV 890 RV navigator
    • RV 895 RV navigator
    • RV 1090 RV navigator
    • RV 1095 RV navigator
    • Tread® - Overland Edition GPS navigator
    • Tread® - SxS Edition GPS navigator
    • Tread® XL - Baja Chase Edition GPS navigator
    • Tread® XL - Baja Race Edition GPS navigator
    • Tread® XL - Overland Edition GPS navigator
The Following Garmin Devices Require the Steps Below to be Seen by the Computer:
  • Camper 795 caravan and motorhome sat nav | RV 795 RV navigator
  • CamperCam 795 Motorhome Sat Nav | RVcam 795 RV Navigator with Built-in Dash Cam
  • Garmin Drive™ 53  | Garmin Drive™ 53 & Traffic | Garmin Drive™ 53 & Live Traffic GPS navigator
  • Garmin DriveCam™  76 GPS navigator with camera
  • Garmin DriveSmart™ 66MT-S | Garmin DriveSmart™ 76 | Garmin DriveSmart™ 86 GPS navigators
  • dēzl™ LGV610 | dēzl™ OTR610 GPS navigators
  • dēzl™ LGV620 | dēzl™ OTR620 GPS navigators
  • dēzl™ LGV710 | dēzl™ OTR710 GPS navigators
  • dēzl™ LGV720 | dēzl™ OTR720 GPS navigators
  • dēzlCam™ LGV710 | dēzlCam™ OTR710 GPS navigators with camera
  • dēzlCam™ LGV725 | dēzlCam™ OTR725 GPS navigators with camera
  • dēzl™ LGV820 | dēzl™ OTR820 GPS navigators
  • dēzl™ LGV1020 | dēzl™ OTR1020 GPS navigators
  • Tread® | Tread® - Base Edition | Tread® 2 GPS navigators
  • zūmo® XT2
1. Select Tap to Connect to Computer
    • If you do not select Tap to Connect to Computer this choice will eventually go away, you will then need to select Settings first.
2. Select Tap to Connect to Computer again
3. Select Continue
You should now see the connection icon.
Connect the USB Cable Directly to Your Garmin Device and not the Mount (USB Ports on Mounts are for Charging Only)
Verify Windows Recognizes the Device
 NOTE: The device doesn't have enough power to communicate with the computer if the display is blank or only shows a Blank battery icon transparent battery icon when connected to the computer. Charge the device while driving using   the vehicle power cable to ensure it has enough power.
A device will display as a removable disk or portable device when connected.
To Verify that Windows Detects the Device:
  1. Connect the Garmin device to the computer
  2. Press the Windows Key () + E
  3. Click This PC (Windows 10 and newer)
Garmin devices will be listed under Devices and drives in Windows 10.
Windows 10 and Newer
Red boxes around found device under Devices and drives
Garmin devices will be listed under Devices with Removable Storage or Portable Devices in older versions of Windows.
Windows 7/8
Red box around Garmin device under Devices with Removable Storage
Device Does not Display the Connection Screen or Display as a Drive in Windows
Try the steps below if your device does not display the connection screen, does not appear as a drive in Windows, or appears as an "unknown device" in the Windows Device Manager.
Try a Different USB Cable:
Mini USB Cable          Micro USB Cable             USB Cable Type A to Type C          USB Cable Type C to Type C
Ensure that the USB Port is Working Properly
  • Try a different USB port on your computer and/or test the USB port with a different USB device
  • Connect the cable directly to the computer. Avoid connecting through a converter cable, USB hub, USB extension cable, keyboard, or monitor
  • On desktop computers, use the USB ports on the back of your computer
  • Avoid using a PowerShare USB port
    • Contact your computer manufacturer if you are unsure whether your computer uses PowerShare ports
Garmin device plugged into a laptop via USB cableUSB cable plugged into the back of a computer tower
         Laptop                     Desktop
  • Check for visible signs of damage to the USB port on the device such as a loose or sagging cable connection.
The Device or the Port May Not Have Enough Power
  • Try powering on the device first, then connecting it to the computer.
  • If a device does not power on automatically after an update when reconnecting to the computer, you may need to press the device's power button.
  • Removing unused USB accessories connected to the computer may allow more power to the port you are attempting to connect to.
  • If the device shows a Blank battery icon transparent battery icon when connected, the current charge level is too low to communicate with the computer. Charge the device. See Low Battery Icon when Connected to a Computer for additional information.
Connect the USB Cable Directly to Your Garmin Device and not the Mount (USB ports on Mounts are for Charging Only):
Back of Garmin device indicating where not to and where to plug the USB cable
Disable USB Selective Suspend
USB Selective Suspend will limit power to connected USB devices, including your Garmin device. It can potentially cause recognition problems.
Contact your computer's manufacturer for instructions to disable USB Selective Suspend.
Garmin Device is Recognized by the Computer but not by Garmin BaseCamp
Other programs may be actively communicating with your device while plugged into a computer. Try closing other open Garmin applications.
  • Example: If Garmin BaseCamp is not seeing your device, but the Garmin Express™ software is, close Garmin Express.
If other programs are not interfering, try downloading and installing the latest version of BaseCamp at https://www.garmin.com/software/basecamp/
See the Support Center for more help with Garmin BaseCamp.
Related
