Editing Targets on a Garmin Wearable
With the Applied Ballistics app on your compatible Garmin smartwatch you can edit and switch between a total of 10 target cards. The information below covers editing the individual target card and the options available to edit:
Editing the Target
  1. From the Applied Ballistics app press Watch with black circle in upper right corner.
  2. Select Target.
  3. Select a target to edit.
  4. Select an option to edit.
Available Options to Edit
  • Target - enter the name for the current target.
  • Range - the distance to target displayed in yards or meters.
  • Direction of Fire (DOF) - the direction of fire, with North at 0 degrees and East at 90 degrees.
  • Inclination - the angle of inclination of the shot. A negative value indicates a downhill shot. A positive value indicates an uphill shot. The shooting solution multiplies the vertical portion of the solution by the cosine of the inclination angle to calculate the adjusted solution for an uphill or downhill shot.
  • Speed - the speed of a moving target, displayed in miles per hour (MPH) or kilometers per hour (km/h). A negative value indicates a target moving left. A positive value indicates a target moving right.
  • Set as Current - sets that target to be used for all calculations.
Related
