Changing Time Settings on an Automotive Device
When your device is locked onto a satellite signal, the time syncs with the GPS satellites. Your device also has the ability to automatically update the time based on the time zone that you are in. If you happen to be in a part of the world where your device does not recognize the correct time due to a change in time zone, you can manually adjust the clock on your device.
Follow the instructions below to change the time setting:
- Touch the time that displays along the top of the screen on the main menu
- Touch the tab next to each of the headings to change the Time Settings
- Touch OK after each setting is selected
- Touch Back after the Time Settings have been changed
The time will now be adjusted.
