Garmin® Marine Device Shows Software Version 0.00
A Garmin® marine device may list its software version as 0.0 if it fails to complete a software update. A forced update may resolve this issue by making the marine device reinstall the software update.
NOTE: Forced updates may not be performed on the following devices:
If one of the above devices shows a software version of 0.0, contact Product Support.
The software update bundle can be downloaded and installed to a blank or formatted micro/SD card. The following items are required to download the update:
A Windows or Mac computer
Windows system requirements: Windows XP Service Pack 2 or newer
Mac system requirements: OS X version 10.3 "Panther" or newer
A micro/SD card (minimum 16 GB, maximum 32 GB capacity)
It is recommended to use a blank card or to back up any files on the card
A micro/SD card reader, if the computer does not have a built-in reader
Forced software updates cannot be completed using ActiveCaptain. The software update files must be downloaded to the micro/SD card through Garmin Express or directly from the Garmin website.
Downloading the software update
Select the computer's operating system below for instructions:
Windows
Insert the micro/SD card into the computer or connected card reader, then select a download method below for instructions:
Garmin Express™
Insert the micro/SD card into the computer or attached card reader
Launch Garmin Express
Go to garmin.com/express to install the latest version of Garmin Express
Select and sign in to a Vessel account
If no Vessel account has been created, select Add a Device > Sign In and follow the onscreen prompts to create an account
Select Software Updates
Read the Important Notes, then select Continue
Read the Terms and Conditions, then select Accept
Select the SD card drive
Select Continue
Select OK
Select Continue again
Allow the software update to finish downloading
Safely remove the micro/SD card from the computer
Website download
NOTE: The software update file must be downloaded to the computer and opened. Downloading the file directly to the micro/SD card will not update the device software.
Select the proper software bundle based on the Garmin device to be updated:
Select I agree to the above terms and wish to proceed to the download page.
Select Download
When prompted, save the file to the Desktop
Double-click the downloaded file
If the message "This publisher could not be verified. Are you sure you want to run this software?" appears, select Run or Yes
After extracting, a new window called Marine Product Software Update will appear. Select Next
Select I accept the terms of the License Agreement.
Select Next
Select the micro/SD card drive
If the drive does not appear in the drop-down list, select Find Drive
Select Next
Select Finish when the installation is complete
After downloading the software update, safely remove the micro/SD card:
On the keyboard, hold down the Windows key + E
Select This PC on the left side
Right-click the SD card drive
Select Eject
The micro/SD card with the software update files can now be removed from the computer or card reader.
macOS
Garmin Express
If the message "Garmin Express" would like to access files on a removable volume appears, select Yes
Select Continue
Select OK
Website download
Choose the proper software bundle based on the Garmin device to be updated:
