Cortex Monitor™ Boat Network fallback
Suppose the Cortex™ Hub is configured to connect to a Boat Network .In that case, if it cannot establish a connection to the cloud for Cortex Monitor™ using its integrated cellular connectivity, it will fall back to attempt to use the Boat Network instead.
To set this up, tap the wrench icon (top left) to enter the Configuration menu from the menu. Go to Networks and select Cloud.
Toggle Allow Boat Network on (right, turns green) to allow Cortex Monitor to fall back to the Boat Network.
