Replacement Bands for the Approach S3
Replacement watch bands can be order on the Garmin website: Approach S3 accessory page.
Replacing the Approach S3 Watch Band
Replacing the band on your Approach S3 takes just a few steps. Before getting started, watch this video to see the process in action - Changing Wristbands on the Forerunner 610 and the Approach S3
Recommended Tools
- A punch tool (provided when purchasing a replacement band from Garmin.com), or paper clip
- Pliers
Removing the Band
- Use the punch tool to push the pin out of the band
- Use the pliers to pull the pin the rest of the way out
- Set the pin somewhere safe
- Repeat the process for the other side of the band
After removing both sides, put the new band on the Approach S3.
Replacing the Band
- Place the band flush with the watch
NOTE: Make sure the band is placed correct for the wrist you wear the watch on. - Place the pin back in the hole and push it in
NOTE: The punch tool can be used for extra leverage to push the pin back in. - Repeat the process for the other side of the band
You have now successfully replaced your band.
