- Hold UP/MENU to enter the Main Menu.
- Select Activities & Apps.
- Select Map.
- Select Map Settings.
- Select Map.
- Select Map Theme.
- Select Marine.
Your theme should now be set to Marine as shown below.
In order to view Marine mapping you have loaded to your MARQ® Collection (Gen 2) watch, you will need to enable the Marine Map theme and disable other mapping installed to the watch. Follow the instructions below in order to make sure that your watch is properly set to display marine mapping.
