Fitting the Protective Cover on a Garmin Chartplotter
Since 2013, Garmin Chartplotters and Fishfinder/GPS Combos include a decorative bezel to attach around the edges of the front of the device. This bezel covers up the screws and holes used for a flush mount installation. In order for the protective cover to securely fit on the chartplotter, the bezel must be installed.
Please note that the protective cover will only fit on a device that is flush or bail mounted. There is not an available cover for flat mounted devices.
For more information on installation of your device, please consult the Installation Instructions for your device.
