Sending Courses From Ride With GPS to Your Garmin Device
There are a few ways to send routes from Ride with GPS (RWGPS) to your Garmin device. Select a method below for steps:
NOTE: If using a RWGPS Experience, see: Manually Uploading a Course to Garmin Connect
Automatically Send Routes by Linking Garmin Connect with RWGPS
Link the Accounts
Setting up your Garmin Connect™ account to wirelessly sync your courses from RWGPS can be done on the web. Follow the instructions below to enable this feature.
  1. Log in to your www.ridewithgps.com account, preferably from a personal computer. If using a mobile device, use the desktop version of the website.
  2. Select the dropdown arrow, top-right corner next to RWGPS logo / your profile picture.
  3. Select Settings.
    animation of selecting settings in ride with gps
  4. Select Connected Services, from the navigation menu on the left, then select Connect with Garmin.
    animation of selecting connected services and Garmin connect in ride with gps
  5. Enter your Garmin Connect credentials in the spaces provided.
    Input boxes for Garmin Connect account credentials
  6. Once logged in, ensure the Courses button is toggled on to enable syncing of Pinned courses to Connect.
    Toggles for Activities and Course
  7. Select Save and Agree to finish the setup.
Once linked, you can use the RWGPS app or web browser to send routes. The routes will appear on your compatible Garmin device and in your favorites list of courses in Garmin Connect.
NOTE: Older pinned routes will need to be un-pinned then re-pinned in order to sync to your Garmin device.
Send the Routes
Sending Routes from Your Web Browser
More instructions can be found on the Ride with GPS website: Pinned routes on the Web
  1. Sign into your account on https://ridewithgps.com/
  2. Select Jump To > Routes.
    ride with gps routes
  3. Find your route and select the Pin icon (RWGPS pin icon).
    pin courses on RWGPS list of routes
    • Or, if you have the route opened, select Save > Pinned in the upper left corner or Send to Garmin.
      RWGPS Pinned
  4. Open your Garmin Connect app and sync your device.
  5. The Pinned route will found on the device and Garmin Connect:
    • Device: Courses > Saved Courses
    • Garmin Connect: More/Menu > Training and Planning > Courses.
Sending Routes from the RWGPS App
More instructions can be found on the Ride with GPS website: PINNING ON MOBILE
  1. Find the route in the app.
  2. Pin the route.
    • Select the Save button, then select Save to Pinned or Send to Garmin.
  3. Open your Garmin Connect app and sync your device.
  4. The Pinned route will found on the device and Garmin Connect:
Back to top
Using the Ride With GPS Connect IQ App to Send Routes
Installing the Ride with GPS Connect IQ app on your compatible Edge® cycling computer will allow you to download recent or pinned routes directly on your device. You can see which devices are compatible by visiting the compatibility list in the Connect IQ app store page at the following link: Ride with GPS.
NOTE: Enabling this feature will only prompt new pinned routes to be synced. Older Pinned routes will need to be un-pinned then re-pinned in order to sync over to your Garmin device.
How Do I Configure the RWGPS CIQ App on My Edge?
  1. Open the Garmin Connect IQ app on your mobile device.
  2. Select the compatible Edge you will be using with Ride with GPS.
  3. Search for Ride with GPS and install the app.
  4. On your Edge, open the IQ store by selecting the IQ button from the device menu. Refer to your owner's manual and search "Connect IQ" for specific steps for your device.
  5. Go to rwgps.com/iq on a web browser.
  6. Enter the Device Code provided on your Edge and Submit.
  7. Select Confirm to link your RWGPS account with your Edge.
  8. Choose a route to download by selecting Recent Routes or Pinned Routes.
  9. Select Download and Ride to save the route and begin navigating immediately or select Download and your course will be found in the saved courses menu of your device.
Back to top
Manually Importing the Course into Garmin Connect
NOTE: This method would need to be used when sending courses from a RWGPS Experience. For details from RWGPS, see: https://support.ridewithgps.com/hc/en-us/articles/4426495649307-Mobile-App-Experiences.
  2. Select the three dots in the top right.
  3. Select Export GPX.
  4. Save the file to your device.
  5. Import this file into Garmin Connect by following this FAQ:  Importing a Third-Party Course into Garmin Connect
Back to top
Related
