Create or Edit a Route Using Shaping Points on a BMW Motorrad Navigator V or VI
The ability to create a route using shaping points is a new feature that was added to the BMW Motorrad Navigator V and VI.
When navigating a trip or route with a shaping point, no alert will be given when arriving at the shaping point.
To create a new route with shaping points on the device
1. Touch Apps
2. Touch Trip Planner
3. Touch New Trip
4. Touch Select Start Location to add a beginning waypoint
    • Note: The start location is not necessarily the point where you'll be leaving. The start location will be the first point you would like to travel to.
5. Use the search options to locate the desired point
6. Touch Select once the point is located
7. Click the plus sign (+) to add additional waypoints to the trip
8. Follow steps 5 through 7 to add additional waypoints
9. Touch the orange flag icon next to a waypoint to turn it into a shaping point
    • At least 3 points are required to use shaping points
10. Touch Next
11. Touch Save
12. Enter a name for the trip
13. Touch Done
A new route with shaping points is now saved to Trip Planner
Edit an existing route with shaping points on the device
1. Touch Apps
3. Touch the trip to edit
4. Touch Menu (3 bars) in the upper left corner
5. Touch Edit Destinations
6. Touch the orange flag icon next to a waypoint to turn it into a shaping point
7. Touch Yes
8. Touch Save
The route with shaping points is now saved to Trip Planner
You can also create shaping points in routes created through BaseCamp™. Please reference the related content for step-by-step instructions on creating routes in BaseCamp™:
Related
