Troubleshooting Map Updates on a Mercedes-Benz Metris/Vito Navigation System
See the troubleshooting below if you receive an error message during a map update on a Mercedes-Benz Metris/Vito Navigation System.
"The map update has failed and must be restarted"
- Touch Retry to attempt the map installation again if you receive this error message
- This will reboot the unit before attempting the retry
- Go through the map reinstall process if retrying the update isn't successful
- See Reinstall Maps on a Mercedes-Benz Metris/Vito Infotainment System for instructions
"The map update files are not compatible with this system"
- Format the USB drive and go through the map reinstall process if you receive this error message
See Garmin Express not Working for Updates and Downloads to troubleshoot Garmin Express errors.
