Adding or Removing Automotive Devices from the Explore Website
The Garmin Explore™  website can be used to sync waypoints and routes with your automotive device. See Overview of the Garmin Explore Website for more info.
NOTE: When using the zūmo® XT2 GPS navigator, Tread® GPS Navigator, and all models in the Tread® series, it is recommended to use the Tread® App for creating and managing waypoints, routes, and tracks. The Garmin Explore website can be used to manage waypoints and tracks, but does not support route creation for the zumo XT2 and Tread devices.
To Add a Device to the Garmin Explore Website:
1. Go to https://explore.garmin.com
2. Select Plans & Devices
3. Select Add Other Device
4. Enter your Product Serial Number, and select Submit
5. Select Confirm
To Remove a Device from the Garmin Explore Website:
3. Select Manage Device
4. Select Remove
5. Select Remove again
Devices can also be removed by deleting from a Garmin account.  See Removing a Registered Product from an Account for information.
Note: The page may need to be reloaded to see changes.
For Garmin Explore Syncing Instructions:
Kawasaki RIDGE 8" Tread Display, Tread® XL - Baja Chase Edition, Tread® XL - Baja Race Edition, Tread® - SxS Edition, Tread® - Overland Edition, and Tread® XL - Overland Edition, see Syncing, Adding, and Deleting Explore Data on a Tread Device.
Tread®, Tread® - Base Edition, and Tread® Textron, see Syncing, Adding, and Deleting Explore App Data on the Tread.
